Washing symbol flashing and machine not starting
    Top Expert:
  • Washing Mach... Master
  • 64,797 Answers
Could be defective door lock or control board call a local repair business
Posted on Nov 11, 2019
4 Suggested Answers
6ya staff
SOURCE:
Jacques De Meyer
  • 500 Answers
SOURCE: Cannot start a wash.
I need your Make & Model to help you with this, please supply me with it, and I would gladly help.
Regards :-}
Posted on Apr 04, 2011
john_cross
  • 6277 Answers
SOURCE: the washing machine isnt starting.
Methinks you could do with a manual for the future!
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
You could also try the manufacturer's web site direct.
Good luck,
John C.
Posted on Apr 11, 2011
caroldon
  • 17130 Answers
SOURCE: hotpoint wma62 normal sign lashing red green sign flashing machine will not start what is the solution ?
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Posted on Jun 06, 2012
Key symbol flashing on screen
Set dial to a program, press start button until key symbol goes out
Apr 04, 2013 | Bosch Washing Machines
Flashing key symbol
wire may have fallen off switch, or shorted
Feb 08, 2013 | Hotpoint WMA74 Front Load Washer
The access door will not open, it is showing the locked symbol in the window
Your problem is either one of the 2 cases below.
1. Door Locked Indicator...'Keyhole' symbol
The 'Keyhole' symbol will illuminate 2 seconds after you have
pressed the 'START/CANCEL' button and will remain lit
throughout the wash programme.
The 'Keyhole' symbol will be flashing at the end of the
programme to indicate that the door is still locked. When the
symbol goes off you will hear a bleep and the door can then
be opened.
2. If the machine has been child locked, deactivate this feature by pressing and holding in the 'child lock' button for 2 seconds.You will hear a beep and the child lock symbol will go out,allowing you to use the machine normally.
Jun 05, 2011 | Hotpoint Ultima WF860 Front Load Washer
Cannot start a wash. When I select programme the time flashes at zero and the lock symbol flashes and the machine is bleeping.
Regards :-}
Apr 03, 2011 | Washing Machines
I am using a candy cty 105 smart. The machine doesnt seem to finish the cycle I washed at 60 and at the end the symbol for heavy solied flashed and the start symbol flashed. I havent used the machine...
i had this problem to.. my solution for this was the wire of pump. wire was just unpluged i just re entered the wire end all was back to normal.. :P
Jan 24, 2010 | Candy Washing Machines
The digital display is showing a KEY symbol flashing, and i can't program a new load. What does this mean?
This is the childproof lock symbol and prevents you from changing a program once it has been selected The symbol flashes if the program is changed during a wash cycle. If the machine is switched off mid cycle with the lock on then it will continue the program as so as the machine is switched back on. To activate the lock press the START button and hold for 4 seconds and the key is displayed. To deactivate the lock press the START button and hold for 4 seconds until the key symbol disappears.
Sep 30, 2009 | Bosch Exxcel WFX 2467 Front Load Washer
Refusing to start cycle. key symbol flashing and a beep
Hol d the start key down for around 5 secs and it will remove the lock. Release the button and press start and it will work again.
Jan 01, 2009 | Bosch Classixx WFL 2066 Front Load Washer
STUCK ON HEAVY WASH
First of all, if you've turned off the Correct power source it would stop running. Keep trying to find the correct circuit breaker. The power must be discontinued and let the dishwasher sit for at least 5 minutes so it can "forget" the program. However, if the same program comes back on, then I suggest holding down the heavy wash symbol continually for several seconds. Or perhaps holding down the cancel symbol for several seconds instead. It sounds like the heavywash symbol is stuck or broken behind it's cover. If the symbol was "jiggled" alittle to the right or left it may become "unstuck". Hope some of this helps you.
God Bless You and your family,
Miss Midget
Nov 02, 2007 | Asko 24 in. D3250 Built-in Dishwasher
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
