Question about Pyle Car Audio & Video
Pyle PLCM4590WIR Hooked up the mirror/monitor temporarily to check it out. When not in reverse the monitor portion of the screen lights for a second then shuts off for a second.
Camera works fine when put in reverse I powered the receiver and mirror off the battery
6ya staff
SOURCE:
Anonymous
  • 94 Answers
SOURCE: No Power in Monitor
If you are a tech. Check the voltages going to the Logic Board, if one is missing (12 or 5v. Then that is most likely due a an IC failure on the power supply board. IC 901 Don't quote me on this, but I know it is less than $10. Sorry, I only have 1 left, the last one I did was in Aug2006 so memory is fuzzy. Kegtapper
Posted on Oct 13, 2006
roskoL
SOURCE: "check connections"
I got the same error on my EX-Z850. The docking station USB cable was plugged into a USB extension cable, which was plugged into the computer. After I plugged the USB from the docking station directly into the computer, the connection was found right away. I think the female end of the extension cable wasn't deep enough to make a good connection.
Posted on Sep 10, 2007
Anonymous
SOURCE: When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why ....
I just replaced the relay on my second-hand NEC2010X . It would go out after some period of time, but come back if I unplugged it and then plugged it in again. It finally died altogether, but when I replaced the relay, it worked fine. Apparently this relay is the weak link on many LCD's (probably the only moving part in the whole thing). So open it up, unsolder the relay, and put in a new one.
Posted on Dec 27, 2007
Anonymous
SOURCE: 17'' monitor whte screen power light on
have a 17'' starlogic flatscreen monitor and i opened a game and it went to white screen and stayed there.
Posted on Aug 14, 2008
muebe
  • 1015 Answers
SOURCE: Monitor Blacks Out Randomly
Well If the monitor is brand new and you just purchased I would take it back and get another one as it appears to be defective. Most stores will allow you to exchange a defective item without a problem as long as you have the receipt. Any attemot to make repairs yourself could void the warranty. If it is used it may still be under warranty...I would get the model/serial number and contact Asus to have repairs made. Most monitors have at least a one year warranty.
Posted on Sep 08, 2009
When put in reverse the image is up side down.
How to Reverse the Image on Backup Camera eHow
EVERYTHING YOU NEED TO KNOW ABOUT REAR VIEW CAMERAS
After installing a backup camera on your vehicle, you need to reverse the image so that the image on the screen matches that of your rear-view mirror. The orientation must match so that the driver doesn't get confused with two conflicting images. The nature of the camera's technology is that its image will be recorded un-reflected, but the mirror will display a reflected image. Fortunately, the engineers who designed back-up cameras thought of this and created simple controls for you to change the orientation.
Read more : http://www.ehow.com/how_6641139_reverse-image-backup-camera.html
Jan 12, 2016 | 2011 Lincoln MKX
Shutter repair
Just out of curiosity, are the batteries in the correct direction? When you half-press the shutter release button, does the meter needle in the viewfinder move?
I can't count the number of times I've put the batteries in the wrong direction on my own FE. I've never damaged the camera, and it works fine when I reverse the batteries.
Oct 01, 2013 | Nikon FE 35mm SLR Camera
Installing a frarview moniter
use a multi meter to check which wires have 12volts
Jul 19, 2013 | Honda Cars & Trucks
On my Nikon D2X the mirror seems to be operatingin
That is backwards...is it possible you put your battery in backwards?
Feb 21, 2010 | Nikon D2X Digital Camera
2003 gmc mirrors do not fold in
The power mirrors are controlled by a module (computer) DDM - drivers door module an the PDM - passenger door module .
Folding Mirror System
Folding Mirror System Controls
The folding mirror system requires signals from 2 separate switches. The mirror select switch must be in the neutral/fold position and the mirror direction switch must be activated to the left/extend or right/retract positions. Both switches are integrated into the DDM and provide direct signals.
Folding Mirror System Operation
Upon receipt of the required switch inputs the DDM will supply battery voltage and ground to the mirror fold motor control circuits to perform the requested extend or retract function. The DDM will also send a class 2 message to the PDM indicating the requested function. The PDM will supply battery voltage and ground to the mirror fold motor control circuits to perform the requested extend or retract function.
Power Mirror System
Power Mirror System Components
The power mirror system consists of the following components:
• The driver door module--Class 2 module with integrated switches and requires programming when replaced
• The passenger door module--Class 2 module with integrated switches, requires programming when replaced and also contains the RFA receiver
• The power mirror direction switch--Integrated into DDM and is a 4-position momentary switch that provides a signal input to the DDM for up, down, left/extend and right/retract with a mirror switch activation
• The mirror select switch--Integrated into DDM and is a 3-position switch that allows the operator to select the left or right mirror and also a neutral/fold position
• The left outside power mirror--Contains both the vertical and horizontal mirror motors and is serviced as a complete mirror assembly
• The right outside power mirror--Contains both the vertical and horizontal mirror motors and is serviced as a complete mirror assembly
• The body control module--Class 2 module that requires programming when replaced, serves as the power mode master and is the main message handler
• The DDM 10A fuse--Located in the I/P fuse block and is hot at all times
• The PDM 10A fuse--Located in the I/P fuse block and is hot at all times
• The memory switch, if equipped with memory mirrors--Supplied power by the DDM and provides a voltage signal to the DDM upon a switch activation
• The horizontal and vertical position sensors, if equipped with memory mirrors--Supplied a 5-volt and low reference by the DDM/PDM and provide a variable voltage signal to the DDM/PDM that is proportional to mirror position
• The park neutral position switch, if equipped with memory mirrors--Provides transmission gear selection information to the PCM and is used for memory recall and mirror tilt in reverse functions
• The powertrain control module, if equipped with memory mirrors--Class 2 module that requires programming when replaced and provides Class 2 message indicating transmission gear selection
• The driver information center (DIC), if equipped with memory mirrors--Part of the instrument cluster which is a Class 2 module that requires programming when replaced and is used to personalize the memory recall and mirror tilt in reverse functions
• Fold motor in each of the outside mirrors, if equipped with power fold mirrors--Provides extend and retract movements of the mirror and is serviced as a complete mirror assembly
Each of the outside power mirrors contains 2 reversible motors to provide horizontal and vertical movement of the mirror glass. The vertical motor operates the up and down directions and the horizontal motor operates the left and right directions. If equipped with power folding mirrors, each outside power mirror will contain a reversible fold motor to operate the extend and retract functions. Each of the mirror motors are circuit breaker protected.
DTC B1722
The driver door module (DDM) and passenger door module (PDM) switch the mirror fold motor control circuits to battery voltage and ground in response to mirror extend or retract command.
Apr 06, 2017 | 2003 GMC Yukon XL
Fuel Pump, power seats, windows and mirror all stoped working at
You might want to check the battery cables and if there is a smaller chassis wire from the battery. Clean these. It sounds like you lost a ground wire somewhere and it is trying to ground through any wire it can find.
Jun 13, 2009 | 1999 Pontiac Bonneville
Electric Mirrors do not work (Drivers & Passengers)
There are two power wires to the DDM - drivers door module .Both are orange ,one is powered by a fuse DDM fuse 15amp . in the left I/P fuse block , plus LT DOORS 25amp circuit breaker .
Do you know what DTC'S are ? Diagnostic trouble codes
DTC B1544, B1600, or B1605
DTC B1580, B1590, B1610, or B1620
• If DTC B1580 is set by itself, the left horizontal position sensor signal circuit maybe open, shorted to ground or battery
• If DTC B1590 is set by itself, the left vertical position sensor signal circuit maybe open, shorted to ground or battery
• If DTC B1610 is set by itself, the right horizontal position sensor signal circuit maybe open, shorted to ground or battery
• If DTC B1620 is set by itself, the right vertical position sensor signal circuit maybe open, shorted to ground or battery.
• If DTCs B1580 and B1590 are both set, the left 5 volt reference or low reference circuit(s) maybe open, shorted to ground or battery.
• If DTCs B1610 and B1620 are both set, the right 5 volt reference or low reference circuit(s) maybe open, shorted to ground or battery.
Need a factory scan tool to test !
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With the scan tool, observe the mirror horizontal and vertical position parameters in the Driver Door Module (DDM) and Passenger Door Module (PDM) data lists.
Operate both the left and right mirrors through the full range of movements.
Does the scan tool indicate that the left and right mirror horizontal and vertical position parameters are within the specified range?
0.50-4.75 V.
Your best bet , take it to a GMC , Chevy , buick or cadillac dealer
Apr 16, 2017 | 2003 GMC Sierra 2500HD
Shutter stays open-battery sign flashes but they are full..
This could be one of a number of problems, but first check the battery contacts are clean. These cameras rely on an elecrtic motor to drive the mirror and prime the shutter. The extra current drawn may cause the voltage to drop if the battery contacts are dirty.
Another possibility is a shutter fault, either the shutter has a sticky deposit or there is an electrical problem. Last time I had one like this I found a crack in the solder connection to the shutter.
Putting a new battery meants the camera will reset to a default setting. This means the shutter will be instructed to fire and the mirror return to it's initial position.
Jan 17, 2009 | Canon EOS Elan 7e with 28-80 lens 35mm...
Can a new battery destroy a camcorder?
It sure looks like it did some damage. At least you've got a work around. If the guy didn't say the battery would work in your camera, it's hard to see how he's at fault. It appears that he did live up to his end of the bargain. Perhaps you should have looked at the battery specs to see what it works with? Even if he's at fault, he probably would owe you only the current value of your camera rather than a new one.
Sep 07, 2005 | Sharp Viewcam VL-A10U Camcorder
Car Audio & Video Logo
35 people viewed this question
Top Pyle Car Audio & Video Experts
Jeffrey Turcotte
Jeffrey Turcotte
Anthony Ward
Anthony Ward
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
