Girbau washing-machine displays L error code, what is the cause
6ya staff
SOURCE:
Anonymous
SOURCE: Error codes
This code is suggesting a motor related fault. Check the brushes in the first instance.
Posted on Aug 31, 2007
prem mathew
  • 1294 Answers
SOURCE: Frigidaire washing machine model LTF2940E
Check your outlet filters, clean out. The machine will not spin if the filter is blocked. Also check your inlet into the machine. Clean screens on both ends of the pipes. Refit carefully.
Posted on Nov 30, 2007
Anonymous
SOURCE: ERROR CODE F07 ON DISPLAY
Solved by heater replacement, cca 7eur in Belgrade.
Posted on Apr 06, 2009
Anonymous
  • 4 Answers
SOURCE: Hotpoint WF860 Washing Machine displaying error F-65
there is no F65, perhaps it's F05 which means it will not empty water (not oumping out). Should av gone to specsavers !
Posted on Apr 17, 2009
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: indesit washing macine displaying error code F-11
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
My girbau washer flashing ALn error,how to fix it? thanks.
its should be that is the Inverter Drive error.
Check to see if the cooling fan is working on the inverter. If not, then when the drive gets hot, it will cut off in the high speed extract.
If the fan is working then it's probably an inverter.
Jun 03, 2018 | Washing Machines
I have a samsung front loading washer and I am getting error code 4E and cant find book help
Water supply problem causing a 'time-out'.
The 4E (4C) error is displayed on the panel of my washing machine ...
www.samsung.com/.../the-4e-error-is-displayed-on-the-panel-of-my-washing-machin...
  1. Cached
4E (4C) ERROR. The 4E (4C) error indicates that the washing machine has detected that there is a problem with the water supply. The most common reason for this error is a blocked or kinked water supply hose.
There are videos here
samsung front load washer error codes 4e Google Search
Apr 05, 2018 | Samsung Washing Machines
OE error please
There may be a few different reasons why the OE error code can display on your washing machine. Is it the LG washer getting the OE error code? The OE error code on the LG washing machine display is an indication of a NO DRAIN issue. The 3 issues that may cause this fault code is a bent drain hose, the drain pump filter is blocked, or the drain pump may have foreign objects lodged in it making it unable to drain. All these issues can cause your LG washer to display the error code OE. With all these different reasons, checking all 3 components will clear the error and fix your LG washing machine.
Oct 29, 2017 | Washing Machines
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    IE error code
    Water inlet error - washing machine failed to fill
    The fault code is displayed, if the washing machine does not detect any incoming water.
    ·Check wiring to water inlet valve
    ·Check water valve
    ·Check drain pump
    ·Check pressure switch
    Check PCB
    Oct 05, 2014 | Daewoo DWDWD3011WW Front Load Washer
    Girbau ms 623 lc-E
    my Englesh is bad, when i start the laudry machine GIRBAU MS623, the display show ALARM U00, i need help
    Jan 15, 2014 | Cars & Trucks
    How can I find a supplier of a replacement door gasket for a Girbau 20lb commercial washer?
    I would suggest staying on the web and doing a product search and you should be presented with suitable suppliers. Just type into your web browser 'girbau washer' and see what turns up. That's what I would do.
    Sorry I can't be more helpful.
    John C
    Feb 16, 2011 | Washing Machines
    Samsung washing machine LE error
    Press "end of cycle". Plug off the wall. Code can be an indication of several issues. The most common cause is over-sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened.
    (that information taken from a link).
    Good Luck!!
    Thanks
    Jul 12, 2009 | Samsung WF203ANW Front Load Washer
    Cl is showing on display and machine wont work
    Press "end of cycle". Plug off the wall. Code can be an indication of several issues. The most common cause is over-sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened..........
    Feb 26, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
    Washing Machines Logo
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Marvin
    Marvin
