Question about Beko Washing Machines
How to fit Drum paddle for beko wmi71441 - Beko Washing Machines
3 Suggested Answers
6ya staff
SOURCE:
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: plastic lug securing paddle in drum have broken off
It is easy to fit.
To remove paddle ,grasp firmly and pull it towards you, then slide new paddle into slots and push firmly towards rear of. drum
You should feel it clip into place..
Make sure you get right paddle as there are at least 3 versions of drum paddles
Plz rate my solution.
Thanks.
Posted on Dec 29, 2008
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: How do I replace Drum paddle on Hotpoint WF860 washing machine
To fit new paddle,line up the lugs on the paddle in the slots in the drum, and push firmly with both hands towards the rear of the drum, you should feel it click into place, make sure you fit it the correct way round.
Please rate my solution.
Thanks.
Posted on Mar 02, 2009
How do I fit a drum paddle to beko wma 767s
The paddles are normally fitted from inside out of the inner tub. You will have to strip the whole machine down to remove the inner bowl and then you can get to the fitting which holds the paddle in place.
Apr 08, 2015 | Washing Machines
Where can i buy a washing machine drum paddle (for inside the machine) one has snapped off today.
How to fit Washing Machine Drum Paddle Lifter
For all free video help on appliance Repairs visitour Video Tutorials
Here's our video guide to replacing a washingmachine drum lifter.
A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple.
The plastic paddles in the drum on the laterwashing machines often come loose and come off altogether. They can bereplaced. call them lifters. You usuallyinsert a small screwdriver down one of the holes (it's the 3rd one on ) andgently press down while sliding the lifter out.
Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines.
There are few types of drum lifter; drum Paddle lifters
Mar 23, 2010 | Indesit W 123 Front Load Washer
Drum paddle keeps coming off had machine blocage
Are you sure you have got the correct paddle, as there is more than one version, and also there is a right and wrong way to fit them.
Make sure you push it hard into the locating slots, you should feel it click into place, to be sure it is located properly, lightly pull it, and it should remain in position.
Hope this helps.
Dec 30, 2009 | Hotpoint Washing Machines
The plastic padddles in the drum keep coming loose I have so far had to replace 5 paddles
Are you sure you are getting the correct paddle, currently there are 3 versions of drum paddles, all different .
Also are you fitting them correctly, it is possibe to fet them the wrong way round, you must make sure that you push them in firmly until you can feel them click into place. after fitting , you should be able to pull on them without too much pressure wiyhout them coming straight out again
Trust this will help you with your prob.
Thankyou.
Nov 26, 2009 | Creda Washing Machines
Replace broken drum paddle on indesit wixl123 washing machine and were to purchase part
On hotpoint, creda, Ariston ,indersit and someother makes see video
To fit new paddle, make sure the retaining lugis up slightly see video, line up the lugs on the paddle in the slots in thedrum, and push firmly with both hands towards the rear of the drum, you shouldfeel it click into place, make sure you fit it the correct way round and youare fitting the correct paddle lifter for your washing machine.
Huge selections of lifters are available on thewebsite DrumPaddle lifters
Oct 19, 2009 | Indesit W 123 Front Load Washer
Drum paddles keep falling out (Hotpoint BWD129 washer/dryer)
I had this problem, and I was advised by the guy who has apparently 'replaced hundreds of these bloody things on this housing estate' to never buy this machine because 'its cheap and ****'
However, if you bend the long central tab ,the one that looks like it does bugger all, upwards into the drum (carefully though, only bend it a little) this will increase the tab tension, and your lifters should last for over six months instead of the previous couple of washes mine was doing.
As for the comment on washing trainers, I put a single towel in my machine and the lifters broke...
Jul 17, 2009 | Washing Machines
Thanks.
Mar 02, 2009 | Hotpoint Ultima WF860 Front Load Washer
Plastic lug securing paddle in drum have broken off
It is easy to fit.
Thanks.
Dec 29, 2008 | Hotpoint WMA64 Front Load Washer
Drum Paddle broken Hotpoint Aquarius
The plastic paddles in the drum on the later washing machines (WMA models) often come looseand come off altogether. They can be replaced. call them lifters. You usually insert a smallscrewdriver down one of the holes (it's the 3rd one on ) and gently press downwhile sliding the lifter out.
Mar 08, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Beko Washing Machines Experts
Eric Taylor
Marvin
Marvin
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
