Question about Frigidaire Refrigerators
I have a Frigidaire FRT21LRG fridge that is in the fridge. Few days ago, it stopped working. The blower was on but condenser was not. So I looked at the rear panel and the overload relay capacitor was burnt out. So I got new parts and replaced it. Refrigerator immediately worked but the issue is the fridge is on all the time. We don’t have a lot of stuff in the fridge so we didn’t notice how long that’s been going on. I’m guessing this is related to some kind of temperature sensor? If so which one should I be looking at? Thanks for the help in advance.
    Top Expert:
  • Frigidaire Master
  • 66,065 Answers
You need freon in it
Posted on Nov 10, 2019
6ya staff
SOURCE:
douglas smith
  • 1462 Answers
SOURCE: Refrigerator not cooling.
compressor has failed. not a diy job
Posted on Apr 25, 2007
Amigaman
Gerald Griffin
  • 248 Answers
SOURCE: ge after replace fan still fan not working
Something to check for. Is the top of the refrigerator door lower than the freezer door? If so the ref. light may not be turning off all the time. Pull bottom panel off to expose hinges. The ref hinge should have an adjuster. Adjust door up to be level with freezer.
Posted on Nov 14, 2007
Anonymous
  • 121 Answers
SOURCE: Fridge stops working for no reason
sounds like the coils may need cleaned
Posted on Nov 29, 2008
Gordon Benson
  • 83 Answers
SOURCE: I have an amana abb1924des.
Hi there
Only bad news I'm afraid, the click and buzzing sound is a seized compressor, you said changed the relay and capacitor, good idea but often a seized compressor will come free if it cools for a while, unfortunately it will normally seize again fairly quickly. A job for the tech guy.
Best wishes
Gordon
Posted on Apr 17, 2011
Danilo Trovato
SOURCE: Capcitor Burnt
Go to the electronic parts shop with the code of the broken piece(or with the brochen piece it self.) You'd pay something like 70 cent for the new varister.Worked for me.NOTICE: Use a tester to check if the other components are good
Posted on Dec 14, 2011
I have a frigidaire model fghb2844lpe that is full of moisture on the rear of fridge. Why?
I appreciate your post, gayannecox!
I see that your Frigidaire refrigerator is building condensation and appearing to get rusty. It sounds like a possible water leak within the cabinet of your refrigerator. I would recommend having a professional technician come out and review your refrigerator to provide an accurate diagnosis. I hope this information is helpful. -Matt
Jan 05, 2015 | Frigidaire Refrigerators
Frigidaire frs26r4 fan not working
So if your voltage changes with the fan plugged in, it would seem that your fan is blown and you need a replacement. This fan is needed to properly cool the top. You should be able to order the part directly from Frigidaire or there are many online sites to choose from. If you need help with this, let me know or if you have any other questions, just ask, otherwise, good luck
Jun 05, 2008 | Frigidaire FRS3R5EMB Side by Side...
My fridge stopped cooling and freezing 4 days ago.I hear fans inside running and it just blows slightly cool air against the ice maker.The compressor is HOT and the main fan for the condensor doesn't seem...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 12, 2010 | Frigidaire FRS26R4A Side by Side...
HI....My Fridge only cools down in the bottom part of it.
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
heatman101
Apr 18, 2010 | Nor-Lake Norlake Refrigeration 4' x 6'...
Not cooling, not freezing either
I assume you mean the compressor was replaced, the condenser is a metal coil, usually a black coated steel. You say the electric is working, so you have power to the unit and im guessing the lights are on..but is the unit running? If its not running, i.e., "it just stopped" its likely not the compressor. Could be one of several controls, or a wiring issue, or the previous servicer was not an EPA Certified Refrigerator Repair Service.
Apr 07, 2010 | Frigidaire 26.0 Cu. Ft. Side-by-Side...
HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
Aug 02, 2009 | Frigidaire Freezers
LG French door fridge freezer not freezing
hopefully you looked out back ...rear lower panel and checked little white condenser fan running...it really needs too to keep temp stable across the condenser coils and no overheat condition to the compressor.hopefully you wont need the $300 circuit board like I just bought
Jun 26, 2009 | LG LFC20740ST Stainless Steel
Freezer works, fridge not cooling but water was leaking from under fridge a few weeks ago, could not find source . Small compact frigidaire unit for dorm room.
Most if not all fridges under $2000 only use a single compressor meaning the refrigeration is provided by venting the freezer air into the compartment. Water under the unit likely indicates the fridge is not properly sealing and moisture is condensing on the cold coils and dripping.
Jun 24, 2009 | Refrigerators
Top Freezer and Fridge not working
WHEN ITS NOT WORKING DO YOU HEAR A CLICKING OR BUZZING SOUND (IF SO BAD COMPRESSOR OR OVERHEATING)SEE BELOW
ALSO CHECK THE CONDENSOR FAN IN BACK IS IT RUNNING WHEN THE COMPRESSOR IS RUNNING
Feb 18, 2008 | Frigidaire FRT8IB5EW 30" 18.2 Cu. Ft. Top...
Fridge Problems
what model and make is it
Oct 30, 2007 | Refrigerators
Refrigerators Logo
47 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
