Question about Electrolux Washing Machines
On my front load Electrolux washer the door does not clasp shut, as if the door is out of alignment....but even when I lift it to clasp, it still does not.
    Top Expert:
  • Electrolux Master
  • 64,803 Answers
Call a local repair service .
Posted on Nov 09, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: Error code E10 on the
E10 is a timeout code. I found the answer on google by refining my search criteria. The tap was not turned on enough for the washer to fill up in time before the timeout was reached. After restarting the washer and turning the tap on further, the washer cycle completed without error.
Posted on Jul 22, 2008
Anonymous
SOURCE: Frigidaire front load, ERR LOC, washer won't run
Just had same problem. After removing boot/rubber gasket around opening, and replacing door lock assembly it still would not work giving the same ERR LOC message! Another site directed me to press the "Options" and "Select" buttons at the same time. BINGO! My husband was quite proud of me!
Posted on Aug 05, 2009
Anonymous
SOURCE: electrolux front loading washer -
I have an Electrolux front loading washer. I just got done washing a load of laundry and the door will not unlock. I tried washing it for a second time thinking maybe it would open again. No luck.
Posted on Oct 10, 2009
torres No9
jamie bryce
  • 27 Answers
SOURCE: error codes for Electrolux front load washer EWF 1087
E40 error is door interlock faulty, could be the lock or it could be the pcb u have to test them.
Posted on Jun 25, 2010
jtej
SOURCE: amana front load washer door locked with door open
To get the front off. (All screws look to be #2 Phillips Screws)
1. You have to unscrew (2) phillips screws from the back that holds the top on.
2. Slide the top off. (slide towards the back)
3. Then where the control panel is there is about 4-6 screws holding that plastic piece on, take those out this will allow you to pull the control panel up and out of the way.
4. At this point you can unscrew the 4-6 screws in the door area that holds the front of the washer on, once you unscrew those screws there is a tab that you have to lift the front over to pull the front off. This will allow you access to the locking mechanism.
5. There are only 2 screws holding te locking mechanism on.
Posted on Nov 18, 2010
Electrolux front loading washer door will not open
Good Morning Nancy,
I understand that the door will not open on your Electrolux washer, model# EWFLS70JSS0. I suggest resetting your appliance, by either unplugging your appliance or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and the door should unlock. Try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Electrolux Washing Machines
My electrolux ewf 1087 front loader door wont open
You will need to remove the drum and reset the alignment.
The cloth is struck and has jammed on the drum movement.
click this link: drum removal
Jan 21, 2013 | Electrolux Washing Machines
Eied55hmb electrolux dryer door adjustment
Good Afternoon Vijay, thank you for your post! From what you have described it sounds like the door strike is not aligning with the door lock or the dryer possibly has a defective door switch. You may want to connect with a local servicer who will be best equipped to pinpoint the problem. If you don't know a qualified technician, you can use the service locator option on the manufacturer site to find one near you.
Dec 31, 2012 | Electrolux EIED55HMB Electric Front Load...
My Electrolux front load will not lock. I close the door and the light goes out but will not lock. The washer is around a year old.
Sounds like the door latch assembly strike is not catching correctly and not telling the sensor the door is shut properly. Contact Frigidaire to see if you have any limited warranty on such a concern and then schedule a professional.
Sep 03, 2012 | Electrolux EW1000i Front Load Washer
Electrolux washer door won't open
Hi.
Usually the door does not open because there is water inside the tub.
Disconnect power and empty the machine through the drain filter. With Electrolux front-loading washers the drain filter access is located in the front lower side of the machine.
Jun 11, 2012 | Electrolux Washing Machines
I have an ATF8000FS1 front loading washer. The door is hard to close and subsequently broke the door strike. If I lift up on the door it aligns the strike better with the latch. There appears to be no...
There is next to no adjustments so if the door dropped then the hinge must be bent . You may be able to very gently pull up on the door and re-align it but most likely you will have to replace the hinge.
Feb 26, 2011 | Frigidaire Affinity ATF7000E Front Load...
The washing machine Electrolux AURUM16 Problem
Make sure the water is drained or the door wont open
Sep 08, 2017 | Electrolux AWF1220 Front Load Washer
Resealing Inner Oven Glass
I guess you worked this out already as posted a while ago....but for others like me I thought adding a solution might help..........Open the door fully and on the hinges there is a clasp, flick that back on itself on both hinges. Close the door carefully and it will stop half way....now lift the door off the hinges. Lay the front of the door on the floor and there are 4 screws on the bottom of the door...unscrew the middle 2 (the outter 2 attach the hinges). then lift off the back of the door....you now have the access you need!
Now i have done this I need to get the sealant....is there a shop you can get this from B
Jul 16, 2009 | Electrolux Ovens
Electrolux front loading washer - door is locked, won't unlock
Nov 09, 2008 | Washing Machines
Wf860 door seal
un-plug the washer take the lid off now open the door undue the clasp that goes around the rim of the door seal on the outside of the washer (look carefully) once done the door seal should push into the washer now if u look into the washer from the top at the front though u will see a another clasp going around the door seal on the inside of the washer this is a screw un-screw it once done then the door seal should pull out repeat backwards to replace it m8
Apr 27, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Electrolux Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Poppa Maddo
Poppa Maddo
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
