Question about Whirlpool Dryers
If it has been working and suddenly, have this problem it could very well be the child lock has been activated.
Posted on Nov 10, 2019
SOURCE: whirlpool Cabrio electric dryer
ctwoods, this sounds like the heating element has shorted to the heater can. What that is doing is leaving the element at 1/2 power on all the time. If this happened, then the heat kept going up until it blew the thermal fuse which caused the motor not to run. So check the heater and any fuses in the dryer. You can go to Service Matters for Whirlpool Service Manuals on this model.
Posted on Feb 03, 2008
SOURCE: du error code on whirlpool cabrio
that code is for the door unlock error. is it possible that you may have tried really hard to open the units lid when it was locked? if so the door lock may have been broken. if not, then try to unplug the unit for a few minutes and try a new cycle.
if the code comes up again then you will have to call for free service as it has a 1 year warranty for parts and labor. yes even if you broke the lid lock!!! dont worry it happens when you get something new and are not sure how it works.
Posted on Dec 29, 2008
SOURCE: whirlpool dryer will not spin
Since your dryer is "new" it is under warranty. I will explain the possible reasons why it will not spin. Then you can decide whether to make the warranty call or not.
If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor
If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch
Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Posted on May 21, 2009
SOURCE: whirlpool cabrio steam electric dryer has sensor light on and does not work
have a problem with my cabrio dryer its powered on but when i push start the sense like comes on and does nother whats the problem
Posted on Oct 14, 2009
SOURCE: Whirlpool Duet Sport Dryer -model WED8300SW2 Dryer
Has anyone found the answer to this
Posted on Jul 17, 2011
Aug 10, 2016 | Whirlpool Cabrio Platinum High Efficiency...
Dec 21, 2015 | Whirlpool Dryers
Nov 10, 2013 | Whirlpool Cabrio WED6400SW Electric Dryer
Dec 02, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Nov 20, 2012 | Whirlpool WGD8800YW Cabrio Platinum High...
Sep 10, 2010 | Whirlpool Dryers
Aug 13, 2009 | Whirlpool WED6400S Electric Dryer
Jun 15, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
