Question about LG LRE30955SS Stainless Steel Electric Range
LG LRE30955SS glass top stove has no power, what could be wrong?
LG LRE30955SS glass top stove has no power after I replaced the front right double burner. I have checked all plugs and screws. There is power through the pigtail to the stove. Could there be a safety switch I missed?
6ya staff
SOURCE:
robert samples
  • 1314 Answers
SOURCE: stove top burner replacement
if your sure you have it wired correctly then replace the switch but first id double check the wiring on the switch
Posted on Jan 10, 2008
Anonymous
  • 29 Answers
SOURCE: My Kenmore glass top range,
SOUNDS LIKE YOU MAY HAVE A WIRE BURNED. CAN YOU USE A MUTIMETER?
Posted on Jan 29, 2009
Anonymous
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Anonymous
SOURCE: burner on glass stove top has turned black
The nice grey-flecked surface coating is very thin; the solid black is underneath. You've "cleaned" the coating off -- that's why further scrubbing just makes it worse. We did the same thing :-(
Posted on Apr 25, 2009
Anonymous
SOURCE: stove top ignition doesn't stop ticking
My Dacor cooktop had a similar problem of continuously clicking igniters. I unplugged it a couple months ago and used a piezoelectric igniter to get it started. Then I looked in the Dacor FAQ and it said to clean the ceramic igniter posts with alcohol not water. I had to scrape some gunk off a couple of the posts with a knife before cleaning with alcohol. Now it works.'
I think the igniters use electrical conductivity to detect when they need to spark, so even slight invisible contamination on the igniter insulator can confuse the sensing system. Also they all seem to fire as a group, so all of them need to be clean because if any one of them is dirty then they will all malfunction.
Posted on Jan 04, 2010
I have a kenmore range # 79094152310. And when I turn on the right front burner, the top of the oven gets so hot you would get burnt if you touched it, is this normal for this stove?
no --not normal
stoves even glass top stoves are only hot in vicinity of the hot plates
if the whole top is hot , call an electrician in to check the systems
Oct 02, 2016 | Kenmore Kitchen Ranges
I have a magic chef stove which has three prong and I just bought a he spectra glass top which it has four prongs could I use the three prong power cord on the glass top
tes you can use 3 prong the left and right wires go on left and right terminals on stove middle wire goes in the middle.
May 14, 2016 | Magic Chef Dryers
LG stove - glass cooktop broken - model LRE30451SW/SB/ST how do i remove and replace glass cooktop on LRE30451SW/SB/ST?
Open the oven door and you should see screws on the overhang where the door fits in,take those off and that should loosen the whole top of the stove,then you will see what to do next and what you have to remove to replace what you need,hope this helps some what.
Feb 19, 2014 | Kitchen Ranges
I broke the glass of my lg 55le8500 tv, can i buy one new and replace it ??? The image works perfect, but the glass is broken ???
All y'all are wrong. It can be fixed. This is one of the only lcd with an actual GLASS front on top of the panel. I cracked mine and got it replaced for about $300
Mar 01, 2011 | LG INFINIA 55LE8500 LED HDTV
We are getting a F11 error message on our new LGLRG3095ST stove. The manual says to check the oven gas shut off valve,which we did and cannot tell if the valve is on or off. Does anoyone have a picture of...
Sorry no solution, my LG stove doing same thing after 3 years. Was wondering if you found what the problem was. Technician wanst to put in new ignitor but I am worried that is not the problem. He did the diagnosis by phone. Any help appreciated.
Dec 22, 2010 | LG LRE30955SS Stainless Steel Electric...
Sears glass top range problem -790.95751990
A room mate burned and severly damage the glass top range. How do I find out about replacing the glass top?
Jan 01, 2009 | Kitchen Ranges
Interior Range Window cracked - How to Replace
It is simple enough not to need a manual.
1- open the door, then pull outwards. The door mounts slide right out.
2- lay flat on a towel on the floor. Remove screws on the inside of the door.
3- remove each piece and layer of the door and glass panels. Set them aside in order so you know how it goes back together
4- replace broken inner glass panel
5- put each piece back together, install screws
6- slide door (mounts) back into their homes on the front of the range
It is surprisingly simple. All you need is a #2 Phillips screwdriver and a bit of patience.
Tip: make sure to clean each glass panel while you have the door apart. Use a razor blade for those stubborn burnt on stains.
Apr 06, 2008 | KitchenAid KGRT607 Gas Kitchen Range
Stove top burner replacement
Jan 10, 2008 | Kitchen Ranges
LG LRE30955SS Stainless Steel Electric Range Logo
22 people viewed this question
Top LG Kitchen Ranges Experts
Marvin
Marvin
Gene Pitts
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
