This picture from Google images implies that the power cord is captured inside the case, that you would need to remove that coverplate in the lower left (philips screwdriver) to install or remove the power cord.
https://www.google.com/search?q=Cielo+46+inch+monitor&sxsrf=ACYBGNQQpIsJCQYdMr7wrJt2tzGjOgBShg:1573328939325&tbm=isch&source=iu&ictx=1&fir=hBnndLjhaoKwDM%253A%252C2TT0Hic9AEULUM%252C_&vet=1&usg=AI4_-kQGhtP2OIT2rNWYiGHoFaCg97js6Q&sa=X&ved=2ahUKEwj4_auE893lAhWUpZ4KHSR8Dh8Q9QEwCXoECAkQCQ#imgrc=hBnndLjhaoKwDM:
'course, i don't know if this is your exact model.
SOURCE: After hooking up this monitor,the 1702 goes
Hi Don,
it sounds like your monitor's Capacitors have gone bad. This is very common. It is repairable, but the caps have to be removed and new ones resoldered on.
If you have soldering skills, not too tough of a job. If not, a shop will usually charge around $100 or so. You will have to weigh the cost vs a new monitor on this one.
Here is some more info for you on the Capacitor plague, that is quite common on monitors now.
http://en.wikipedia.org/wiki/Capacitor_plague
SOURCE: InFocus LP540 Power Supply Problem
most of infocus parts are oem and made by a company in taiwan that no longer makes power supplies, and many of the parts have their stock numbers and not neccesarily a common stock. the power supply, however, is in stock at infocus for about $65.
SOURCE: My Acer LCD Monitor AL1707A goes blank after 2 seconds
Try this,
When laptop on booting immediately press del.
And the screen will run normally.
But if the screen is still white, force to press power button soon.
And it will shutting down.
After shutting down, repeat this action.
It will work.
Vincent-Jember
SOURCE: My 20 inch Dell Monitor keeps shutting down..
mcdevito75 here, Sounds like the monitor itself, contact Dell for rep[lacement on warrantee if warrantee applies.
SOURCE: my tv sony bravia 46" are still not workin i still
So before ordering that expensive main board, you may want to read below and check the T-CON board also: Troubleshooting a "DEAD" TCON Many of the Sony television models over the last few years will detect a TCON that has completely failed. The communications data between the video process circuits and the TCON will cease to communicate if the TCON fails completely. This will cause the television to shut down and display a diagnostics code indicating a failure of the TCON. Not all chassis designs have this feature and it is not found on older models. The typical scenario when this failure arises is for the technician to bring a video process board to the repair location. It is usually safe to assume that the problem lies on the TCON board if the replacement video board does not remedy the problem since it is highly unlikely that a replacement board with the same failure was received. One trick to check most TCONS for functionality is to loosen the LVDS connector at the TCON (as shown In Figure 3) while the unit is turned on. Handle the LVDS connector with care and be certain to fully release the lock tabs. Gently rock the cable in and out of the connector while observing the screen for any response. Depending on the chassis, the symptoms of the screen may be gentle white flashes, intermittent colored lines, or a screen full of random patterns. The idea at this point is to provoke some kind of response on the screen. TCON boards that have failed will not usually generate any type of response on the screen. Another helpful procedure is to rapidly heat and/or cool the TCON with hot air devices or circuit coolant and
This is from SONY's how to troubleshoot T-CON board/LCD panel problem:
PM me if you wnat me to send you the whole artical, [email protected]
watch for patterns to appear on the screen."
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
