Question about Panasonic Televison & Video
What's D-IN-TV on display
Panasonic DVD player says Hello then letters that look like D-IN-TV
6ya staff
SOURCE:
Anonymous
  • 117 Answers
SOURCE: Panasonic PV-20DF64 20 inch TV/DVD Combo TV can not read disc
If the disc loads up and you can hear it spin, then you get the error, more than likely the optical lens has been damaged. This will have to be repaired by a local shop if its worth the cost. if the part is available it would probably run anywhere from 130-165 to repair
Good Luck!
Ruben
Posted on Jul 23, 2009
dennis bullard
  • 4090 Answers
SOURCE: dvd player wont read displays H2O panasonic 2001 model
try cleaning the scanner eye with the cleaner disk
Posted on Aug 19, 2009
Anonymous
  • 63 Answers
SOURCE: My Panasonic DVD Home Theater player will not
Check and correct the speaker cable connections.
Posted on Aug 20, 2009
kirtec auto
  • 1348 Answers
SOURCE: Panasonic DVD-A120U Problem with disc in player
either the laser is burnt out,or the disc motor is no good.
locate the peice that the cd sits on.spin it.if it reads the disc after,the motor is no good.
Posted on Sep 01, 2009
Don Matthews
  • 309 Answers
SOURCE: Panasonic DMR-ES15 DVD recorder startup failure
The unit failed during self check, probably the power regulation board. A check by a qualified TV/VCR repair person is in order.
Posted on Nov 20, 2009
No signal, just says Hello
you have to put a DVD in it I think .
Sep 23, 2015 | Panasonic DMP-BD80K Blu-ray/DVD Player
How to hook up to panasonic tv & sony dvd player
DVD output (HDMI) to HDMI input on TV will transfer both audio and video from DVD to TV. Audio output on TV to unused Input on Yamaha receiver (Aux, CD, etc.). This hookup will allow DVD and TV channels audio playback through your Yamaha receiver. Remember to test any/all new hookups or connections using minimum settings (volume, etc.), and bring up levels slowly for the initial testing.
Mar 31, 2015 | Yamaha HTR-5930 Receiver
DVD output to TV not displayed
So you have HDMI off of the PVR into the TV and AV off of the DVD Player into the PVR at the moment? Just for info what connectors do you have at the back of the tv, dvd and pvr? In's and out's...
Feb 28, 2014 | Televison & Video
Dvd s58 how to make it multy zone
hi,
To make your dvd player region free ,you also need a pansonic tv's or home theater's remote. Do the following with the two remote to make you player region free.
The new Panasonic DVD players DVD-S38 & DVD-S58 have a different way of being multizoned. An extra Panasonic remote is required ie: from TV or home theater:
Power On, Tray Open.
Using remote control included press: Audio, 1, 9, 8, 2. Press Subtitle.
Using another Panasonic remote press Pause.
On the remote included, press 0.
'On' will be displayed on the unit.
ok
Apr 11, 2011 | Panasonic Dvd-s58 DVD Player
I have the closed caption on my TV, and when i go to menu, its set up as OFF and the letter would no go away
Is this while watching a dvd? DVD players captioning might be turned on. MAke sure both are off on your tv and dvd player.
Jun 17, 2010 | Panasonic TCP42C1 Plasma TV
Blueray screen shows "hello" "play" "dvd" and "setup." I cannot get a display screen or onscreen menu.
What cables did you use to connect the dvd player to the tv? If you used the composite, make sure the yellow is connected to the yellow.
Feb 11, 2010 | Panasonic DMP-BD605 Blu-Ray Player
Nov 20, 2009 | Panasonic DMR-E55 DVD Recorder
How can I unlock my panasonic dmp-bd80 blu ray player. I see you can buy region and code free panasonic dmp-bd80 players but you still need a converter for the TV. I currently use an unlocked or zone free...
To return to the factory preset
(No setting)
≥Reset the unit as follows:
1 Press [POWER í/I] on the unit to turn off the unit.
2 Press and hold [;], [POWER í/I] and [< OPEN/CLOSE] on the unit at the
same time for more than 5 seconds until “HELLO” is displayed on the unit.
3 The power will turn on and then turn off.
Sep 22, 2009 | Panasonic DMP-BD80K Blu-ray/DVD Player
Panasonic DVD-R30 Displays ''locked''
My problem was solved by holding the back button open button and pause button at the same time for 3 seconds.
Feb 16, 2009 | Panasonic Televison & Video
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
