Check the remote control for its infra-red emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
SOURCE: POLAROID 1511-TLXB LCD TV Remote Code for Verizon FiOS STB
I posted that as a point of information. I noted from searches that other people were having remote code problems w/that TV set. Code 0205 worked for me.
SOURCE: Verizon FIOS remote buttons all work except
I had the same problem with a Sony Trinitron KV-32FS320 32" TV. I reset the remote to factory default.
Then I reprogrammed the TV control.
After this, the volume + and - worked to control the TV.
I hope this works for you.
SOURCE: I need remote code for my Verizon FIOS remote to
Paper says go to the next number... in this case it is 0205, works for me!
