Today I push the power button to turn on the TV, but I hear a different sound and the tv won't turn on
Might be a problem with its Power Supply Regulator Board [SMPS] inside.
If you wish to get some details; check the sites linked here.
https://elektrotricks.blogspot.com/
https://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault. Search the site by type in the Brand Name of your set, in its search bar at the right side column, and press enter. See it in by Webview with mobile or by desktop. Mobile View has no search box. Screen-shots to defective LCD panels are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent.
SOURCE: Sharp Aquos LC-26D4U sound problem
Well, apparently this is a huge problem with many flat screen TV's. They surpress the volume output from all external sources (like DVD players) so you don't blow up their tiny speakers. They just expect you to add on a home theatre system to boost the volume their small speakers cannot handle. This is a real problem if you are in a boat or RV and do no have the space or electrical capacity to do this. I had the TV checked out and Sharpe said it met their factory standards so there was no help there. We have had to go with a small amp & speakers just to hear the TV & DVD movies etc. They need to put better quality speakers in these TVs. The video is awesome, now work on the audio guys!
SOURCE: No picture when I turn the tv on only sound
TRY CALLING BEST BUY'S GEEK SQUAD TO COME FOR A IN-HOME REPAIR SERVICE CALL AND THEY WILL FIX YOUR PROBLEM!
SOURCE: my tv will not turn on
your tv set is in auto protection mode.
sum times its due to a power line falur or a power surge to the set and other times its due to parts failing inside the set.
depending on the age of the tv, you might want a repairment to take a look at it.
best regards,
daniel.
SOURCE: Sharp LC-37SB24U will not turn on
I can tell you 100% that the problem that you are having will be a service issue. I can also tell you that your limited warranty covers in home service from sharp. Give them a call 1-87-SEE AQUOS(the advantage line that will get you through much quicker). or the 1-800-BE-SHARP and let them set you up for service, sharp will take care of that as long as the purchase date of your tv was within 1 year. If you dont want to go through that, I suggest taking the tv back to where you got it from if they will accept it because unfortunately, this problem can ONLY be resolved through service. good luck & keep me posted
