Question about Kurzweil SP3X 88-Key Stage Piano
Kurzweil SP3X LEDs+lights don't work?
Kurzweil SP3X works fine, except LEDS (3) and all button backlights do not work and do not flash on startup either. What may be the cause of this?
How do I repair or replace a Korg i3 piano keyboard's display light?
If it's just the backlight, and you're good with a soldering iron, here's a link to the supplier I use. http://www.telesisgear.com/id16.html
This Youtube video will give you an idea of what's involved even though it's for a different instrument
Korg Wavestation Replacing Backlight by Davide Solurghi Morpheus2027
Feb 19, 2015 | Korg Music
Cuts out on me while playing
If you';re sure it's the instrument, rather than your amp cutting out or the cord being intermittent, do a factory reset. Beyond doing a reset, it's doubtfull this will be a user servicable problem. You need to contact Kurzweil Support. Here is a link to their page
Support Kurzweil
Feb 08, 2015 | Kurzweil SP3X 88-Key Stage Piano
Tell me some tips and tricks about using the Kurzweil sp3x stage piano
The place to get the best help for Kurzweil gear is Sweetwater Sound.
Other than that, always use it in stereo mode with a decent sound system. Always use speakers with at least a 15" woofer and a horn to get the full range of sound it's capable of.
May 18, 2014 | Kurzweil Music Systems Kurzweil SP3X...
Gets whacky and freezes up every 2-3 minutes
Is this the correct sustain pedal for this unit? It sounds like it should be a momentary button type. I would look into that. Some have a push to work type of switch and some use momentary. If it is, I would open that pedal and clean the switch with contact cleaner, as it appears to be sticking.
May 22, 2012 | Kurzweil SP3X 88-Key Stage Piano
I have a Digitech wammy 4 v pedal the led light are going out i have 3 lights left how can i fix the led light the pedal works fine with out the lights
Check the burned out LEDS with a 3 volt battery- a computer bios battery works well for these.
If they do not light, which is likely, just replace them with similar sized units. You can even change their color too. Measure the voltage at the LED sodler pads to see if it is more than 3 volts, if it is, add a resistor to drop the voltage and limit current to the replacements. Digikey sells them, and they ship around the world http://www.digikey.com or Mouser, Both are based in the US, I am not sure what Mouser's international shipping is. http://www.mouser.com
If there is no voltage at the LED pads, look for bad solder connections, or burned out resistors. If the few remaining LEDs still operate as they should, the level meter chip "should" be okay.
Feb 14, 2012 | Digi-Tech Music
Hello, My KURZWEIL start but it only blinking a rectangel on display to the left. There is no other lights, all other is dead Morten Lauritz
It could be your internal battery. Do a search on keyboardforums.com for additional support or Kurzwil website. good luck!
Sep 15, 2011 | Kurzweil SP3X 88-Key Stage Piano
When i turn the sp3x on, the screen just blinks
That happened to mine. All I did was hard reset it.
May 25, 2011 | Kurzweil SP3X 88-Key Stage Piano
I brought my kurzweil sp 3X to a store to have them installed a new board on it, but after they installed the new board in, the character displayed on the screen are all in a weird organize and messed up....
It sounds like the new board and firmware has gone to abbreviations instead of fully spelling it out.
I would complain to the store since they should warrant it if it is a problem... but be prepared to accept that the firmware has been changed and displays differently now.
Mar 23, 2011 | Kurzweil SP3X 88-Key Stage Piano
After transport the keyboard,half of the keyboard below c4 not work.
Probably a cable has come loose inside the unit. The keys are scanned by the internal processor as a matrix of two contacts per key. Often the keyboard is divided into two sections.
You will need to have it repaired or if you are electronically adept, open the case and look for obvious problem.
Mar 17, 2011 | Kurzweil SP3X 88-Key Stage Piano
BR8 Digital recording studio lights up, but it doesn't do anything else
I called Roland at the number that you provided and gave they following proceedure which will re-intialize the BR 1180 and ERASE everything that was created on the HD:
  1. Simultaneously hold down button beneath volume control at track 5 and Undo/Redo button at upper right
  2. Press power button while holding down buttons as above, until test menu comes up
  3. Turn selector dial untill initialize screen shows
  4. Prdess ENTER and initialization will start
  5. Once initialization is completed, power off unit and then power it back-up.
NOTE: This proceedure erases all data!
Apr 16, 2009 | Boss Micro BR Digital Recorder
Kurzweil SP3X 88-Key Stage Piano Logo
27 people viewed this question
Top Kurzweil Music Experts
Wbix
rhodesworks
tmaree
tmaree
Are you a Kurzweil Music Expert? Answer questions, earn points and help others
