Question about Sony Televison & Video
Sony model KP-53HS30 works fine just no picture black screen.at first i could tap on back where rca jacks plug in,and the projection lights would come onnow that does noy work
6ya staff
SOURCE:
Lashawn Robinson
  • 1153 Answers
SOURCE: double images--3d view--ghost picture Sony KP-53HS30
The convergence amps are the big STK's*** located possibly on the G-board in the sony. It is very difficult if you are not familiar with components and soldering, You can buy them at MCMelectronics, bluestar-online.com, Tritronics, VanceBaldwin.com, etc. Diagrams are online at fixya.com on the rightside of screen. Places like Manual.com or you can search the web. Hope this helps!
Posted on Sep 24, 2007
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: Sony KP-53HS30
sent the info to your email address
Posted on Mar 31, 2008
Anonymous
SOURCE: Sony KP-61HS10 61 in. Rear Projection Television
my tv has the same problem but it blinks five time with no picture but good sound
Posted on Aug 01, 2008
Anonymous
  • 13 Answers
SOURCE: Sony wide screen projection tv model kp-57wv600.
I found this solution from SONY's website.
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
I hope this helps.
Posted on Aug 05, 2009
russtash
  • 160 Answers
SOURCE: I recently bought a Sony KP-53HS30 rear video TV
Hello Sarah!
There is no bulb to replace in your TV. Image is created by three CRT's and you don't want to replace them, just trust me on that one. It could cost you up to $1800 to do that.
All you can do is to clean lenses of those CRT's. You have to disconnect TV from the power outlet and remove rear cover. Using very soft brush and vacuum cleaner remove dust from Red, Green and Blue CRT lenses. Do not use solutions unless you got something special for optics. Solutions will leave film on the surfaces. That would improve brightness and contrast of image.
To adjust focus front grille have to be removed. Than central piece cover held by 5 screws. Behind it you can locate black plastic "box" size little smaller than cigarette pack. there are 6 adjustment "screws". Three of them are "screen". You don't touch those. Another three "focus" there is one for each color. Turn TV on. Hit "menu" button. And adjust focus for each color separately. If menu goes away hit it again.
This is the only improvements you can do.
Everything else will involve humongous amounts of cash.
Russ.
Posted on Apr 04, 2010
TV works fine for about 3 minutes then the picture goes black and the red light on the front of the TV starts blinking. The sound works the entire time. If I shutdown the TV and wait a few minutes and...
The light is blinking a code. The code will be a series of blinks, a pause and the blinks again. Phone Sony service and give them this code. They will be able to advise you as to the problem.
Apr 03, 2010 | Sony KP-53HS30 53" Rear Projection...
The standby/timer is flashing 6 times on my Sony KP-53HS30 TV
no the 6 blinks indicates a missing voltage. If your talking about a sony lcd KD or KE model you probably have a bad thermal fuse. You must also clean or change the Lamp fan so it won't blow again.
Apr 16, 2009 | Sony KP-53HS30 53" Rear Projection...
Sony projection tv kp-53hs30 made nov.2003
do you think you can take a picture and send it to this website
Aug 08, 2008 | Sony KP-53HS30 53" Rear Projection...
Status light blinking
your flyback is bad on the D board thats what makes the led blink 8 times replace the flyback and you should be fine. If you need a link on where to get the flyback and instructions on how to change it let me know and I will post a link
May 25, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony KP-53HS30
Mar 31, 2008 | Sony KP-53HS30 53" Rear Projection...
Viewing HDTV on a Sony 53" KP-53HS30
This TV is a projector - not a plasma. I can't see how you would get "burn in" on this set. It should handle an HD picture fine.
Jan 06, 2008 | Sony KP-53HS30 53" Rear Projection...
Double images--3d view--ghost picture Sony KP-53HS30
Sep 24, 2007 | Sony KP-53HS30 53" Rear Projection...
Televison & Video Logo
20 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
