Question about RCA Televison & Video
Is there a manual reset button on a RCA DTA800B1 digital tv converter without a remote?
    Top Expert:
  • RCA Master
  • 54,974 Answers
No, there isn't
Posted on Dec 10, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: Remote codes for RCA Digital TV Converter Box (DTA800B1)
I was just looking for them and then found my manual and felt bad for you guys so I scanned it and uploaded it to photobucket ^^ please feel free to save the remote codes but you may have to zoom in alot to see them ^^
http://i37.photobucket.com/albums/e83/Megumi_Kurama/Scan007December152008.jpg
http://i37.photobucket.com/albums/e83/Megumi_Kurama/Scan006December152008.jpg
Posted on Dec 15, 2008
jumon
  • 18 Answers
SOURCE: I have an RCA converter box hooked up to an RCA tv
Basically, you cannot use the coax connections for both the VCR and the RCA converter box. I would hook up the phono/cinch connectors from the VCR to the TV if you can (these are also called RCA connectors, but I'm avoiding using that name so we dont confuse the digital receiver with a cable/connector name that is the same here). There should be a yellow one for video and red/white ones for left and right stereo. I believe the RCA converter comes with a three headed cable that can do this for you. With this configuration, you can set the TV to input on these connectors and the VCR should always output there. Once that is set, you can still use the converter box to receive the signal from your antenna, then run the coax to the VCR. Now, the VCR will always have to be set on channel 4 in your setup and you will need to manually change channels on the converter box for it to record a show. Does this make sense so far?
Posted on Feb 27, 2009
Anonymous
  • 111 Answers
SOURCE: Remote Codes for Digital TV converter remote do noy work
try:0607-0204-0321-0508-0326-0993-0802-0108-0308-0715-0463-0053-0606-0653-0508-0160-0371-1172-and finally 1253.
Please rate!
Posted on Mar 13, 2009
Mick
  • 325 Answers
SOURCE: I need codes for a rca DTA800B1 converter box so I
Hello Mitzisexton8
Here are the codes for Quasar 012,038,092
Hope this helps you out.
Cheers Little Dish Fitter
Posted on Oct 11, 2009
John Morganti
  • 864 Answers
SOURCE: Need remote programming codes for RCA Digital Converter DTA800B1
Use the SKU number of the RCA remote to look for the code here. Click on "Find your Remote Codes Here" at the left side of the screen.
Posted on Dec 22, 2009
I have an rca converter box model number DTA800B1. I unpluggd it briefly and now don't have the code toprogram it
DirectTV remote model Rc64 will control the RCA model DTA8001B1 digital receiver. Set the remote's switch to unused AV1 or AV2 position, simultaneously press and hold mute and select buttons until indicator gives a double flash and immediately enter code number 00392 after which the indicator will double flash in acceptance. Works menu and it's navigation, channel up and down, and numerical keypad.
Mar 12, 2015 | RCA (DTA800B1) Video Converter
I have an RCA TV converter box, model DTA800B1. I don't have the box or instructions, I am attempting to conneect it to an RCA TV with a built-in DVD player. I would appreciate the code that the TV...
There are a lot of possible RCA TV codes programmed into the DTA800B1 remote.
Try the following three digit codes: RCA 000, 001, 005, 072, 073, 074, 075, 076, 077, 078, 135,
138, 140, 144, 150, 156, 159, 162, 163, 169, 171, 178, 229, 246, 249, 260, 274, 275, 293, 302 in order.
To program the remote. Turn on your TV manually and press PGM (to the left of the zero in the number pad section). The LED should light and stay lit. Type in the first 3 digit code and press OK (in the center of the arrow keys near the top). See if the gray volume up/down keys work to change the volume. If it doesn't work press PGM again and enter the next code.
Note that the converter box remote will only turn on and off, switch the input from Channel 3 or 4 to AV in, adjust the volume and mute the TV. It will not control any of the DVD functions. Your original TV remote will not control the converter box.
The manual for the DTA800B1 is available here: http://www.1800customersupport.com/productdocuments/DTA800B1_RCA.pdf .
I hope this helps.
(who has the DTA800A which is the model without the analog pass-through.)
Sep 17, 2011 | RCA Televison & Video
Have an rca digital converter box model dta800b1 and a phillips universal remote can i program it so my box get the channels
Find the user guide for your universal remote and use the RCA cable tv/satellite codes, and one should work for your RCA DTA800B1 converter box. My Sharp Aquos remote liked the RCA satellite code.
Jun 04, 2010 | Televison & Video
RCA DTA800B1 coverter box & LXI 13" TV - need remote code
You may have to try using a separate universal remote control.
Feb 07, 2018 | Apex Digital AT1308 13" TV
Please rate!
Mar 12, 2009 | Televison & Video
Lost codes for RCA DTA800B1 converter box
rca converter box syvania tv codes please thank you robert
Feb 01, 2009 | RCA Universal Remote Control
Televison & Video Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
