Question about Mitsubishi Televison & Video
I have a Mitsubishi tv, Model WD-73736. When replacing the lamp, the screws won't seat. I think it may be burred out.Should I try a bigger size screw or something else. Any help would be appreciated.
6ya staff
SOURCE:
ctf1800
Cary Farah
  • 4402 Answers
SOURCE: mitsubishi dlp does not get picture
the plug the connects underneath is not connecting right you have to get at the plug and seat it correctly
Posted on Dec 08, 2007
Anonymous
  • 556 Answers
SOURCE: Mitsubishi tv model # wd-52527, lamp light flashing,no picture.
I would say so.
Posted on Aug 18, 2009
Anonymous
SOURCE: Mitsubishi WD-52631 HD TV lamp problems
So far I have had no good luck with Mitsubishi. I have had them send me two bulbs and had the tv repaired in the two years I have owned it. My last tv lasted 14 years with NO issue and didn't cost me $1400!! I have been told there is an air flow problem and power supply problems which both lead to low lamp life. I think that if Mitsubishi wants to avoid a class action lawsuit they need to start giving away free lamps for this model. Also, this is not localized to just the 52" tvs. My wifes ex has the 62" and it has the same issues.
Posted on Oct 23, 2009
Steve Yocum
  • 668 Answers
SOURCE: mitsubishi wd-73736 bulbs buzzing noise
The Ballast that ignites the Lamp could cause the Lamp to fail and/or cause a buzzing noise. That being said, the Color Wheel in the Optical Block assembly could also cause a similar symptom. If Mitsubishi would be willing to help with the Lamp cost, I would call a local Mitsubishi repair facility to install it and see if the noise is still there and find out exactly what is causing it. Mitsubishi Customer Service Phone number is 1800-332-2119.
I hope this helps,
Skyassoc
Posted on Oct 26, 2009
phil_frye
Philip Frye
  • 295 Answers
SOURCE: Mitsubishi WD-65733 no picture, electrical buzzes in series
What it sound's like is that the lamp ballast is the problem. Buzzing sounds like when the power is first brought to the ballast it has to ramp up the voltage to get the lamp to light, then the voltage drops back down when the lamp is lit. Sounds like the lamp ballast isn't ramping up the voltage the way it should. May have to replace it. A good service shop would be able to do this for you.
Blessings,
A/V Media Guy
Posted on Nov 20, 2009
Testimonial: "very helpful. this was my first thought! thank you!"
Tip
Mitsubishi wd65733 lamp problems
if you have replaced the lamp using the old cartridge that houses the lamp this is a little secret if you are still having issues with the tv not working.
For some strange reason the cartridge might not seat properly and the screws that hold the cartridge in the tv might not grab. If the picture is abit dim this is for you to.
Try this: Where the screw go throught the cartridge and screw into the t.v. is there the problem lies. It kinda loos like two ears top and bottom of left side of cartridge. the thickness of the ears where the screw goes through is now too thick to allow the screws to grab! You need to grind the tabs down so that the screws can reach further and male it to the prethreaded holes in the tv. This will also allow the housing to seat further down eliminating the dimness problem. This also will fix the prolem of te tv only sparking the ballast and not firing up the lamp. Give it a try. Be cautious on how much u grind. Go slowly and take your time! Clean that color wheel also!
on Apr 28, 2010 | Mitsubishi WD-65733 65" HDTV
Mitzibushi Tv model WD-65638 no picture no sound
Youre lamp has failed. you need to replace the lamp. Refer to the manual to see how to replace it. It only requires 2 or 3 screws on the back to be removed. Please check the manual.
You need a 915B441001 lamp. 915B441001 PVIP Mitsubishi DLP TV Bulbs
Feb 25, 2015 | Mitsubishi Televison & Video
Where i bulb located on a mitsubishi wd 62525 rear progection hd tv?
Through the front of the TV. Remove the speaker grille (IT SNAPS OFF & ON) & there is a lamp cover with 3 screws holding it in place, near the left speaker.
That lamp part#: 915P020010 $49.00 TO $100.00
http://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-62525
Jun 03, 2014 | Philips 60PP9202 60" Rear Projection...
I replaced the lamp for my Mitsubishi 915b403001 tv and the "lamp" light is still on
you need to reset the timer
I will tell you the way to reset the timer ,Pls let me know your Projector's Model
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD,
motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Oct 12, 2013 | Mitsubishi 915b403001 Lamp For Wd-73735 /...
Lost screws
Well, if it won't turn on, the problem is more than just a screw.. you can get screws at any hardware store, just take one in there and ask them to find one that matches it. As for your TV not working... it may be the power supply.
Jun 08, 2012 | Mitsubishi WD-65738 Medallion 65 3D DLP...
How do you change a lamp on a wd-60735
First order the correct lamp for your TV. Order from www.mitsuparts.com if the unit is out of warranty. The lamp part number is 915B403001. Next make sure the TV is off and has cooled for at least one hour. Use a Phillips #2 (large) screw driver to remove the cover from the back of the TV (on the lower right hand side). Next loosen the two screws (Phillips #2) that hold the lamp cartridge (they do not come completely out of the cartridge). Open the bag that comes with the new lamp and set it aside. Grasp the handle on the old cartridge and pull it straight out. Put this lamp into the bag. (Be careful to avoid tilting or rotating the lamp since that could cause glass to fall out of the unit.)
Carefully handle the new lamp (do not touch the glass - wear gloves if possible), Insert the lamp cartridge into the TV in the same orientation as the one you removed earlier. Push it into the TV until it is fully seated. Tighten the two screws with either your fingers or the screwdriver. Do not overtighten the screws. Replace the cover and tighten that screw.
You can get the manual from Mitsubishi support: http://www.mitsubishi-tv.com/support.html . Click on Product Documents and search for the model number. The directions start on page 75 and includes pictures of the procedure.
I hope this helps.
Jan 20, 2011 | Mitsubishi WD-60735 Projection Television
Mitsubishi wd-73736 bulbs buzzing noise
I hope this helps,
Skyassoc
Oct 24, 2009 | Mitsubishi WD-73736 Television
How do you get to the bulb on a Mitsubishi 1080p model wd-52628?
look to the right side of tv front remove the 2 screws watch how the filter comes off to replace back look for 3 screws on the lamp remove them and pull the lamp out replace is opposite of removal
Apr 01, 2009 | Mitsubishi WD-52628 52" Projection HDTV
I have a 4 month old Model WD-73736 tv that is nonresponsive
i'd take it back!  it's obviously defective.  TV's are supposed to last longer than 4 months!
Mar 27, 2009 | Mitsubishi WD-73736 Television
Televison & Video Logo
43 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
