Televison & Video Logo
Louie Rodriguez Posted on Nov 11, 2019
Have a 70' Vizio TV. Have sound no video. Replaced T-Con board, still have no video
Metal
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Sep 27, 2020
Metal
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
0
Helped
2072
Points
34
Have you tried shining a bright light on the screen while it is playing to see if the picture is faintly visible? Could be a blown backlight due to the faulty board you replaced.
5 Related Answers
Anonymous
  • 132 Answers
  • Posted on Aug 29, 2010
SOURCE: I have a Samsung LCD TV Model LN-S4692D. I lost
You might want to try reseating all of the ribbon connectors that connect to the tcon first, but it sounds like you may have a bad panel(screen) which is probably what made the original tcon die. The only other possibilty would be the backlight inverter board(either the master or slave depending on which side the dark area is on).
Anonymous
  • Posted on Oct 18, 2010
SOURCE: i have a vizio vp422hdtv10a i have sound but no
Hi!! I got problems with my Vizio 42". Have sound but no video. I replace the video logic main board and fixed the problem but a few days later the same problem came back. Before this I also replaced the backboards. Any help from someone?
Anonymous
  • 1238 Answers
  • Posted on Aug 25, 2012
SOURCE: vizio m420nv has sound but no picture
Hello there
Actually that problem is very common on all LCD TV,, that problem is cause of either inverter board or t-con..
In this case you don't need to check the voltage that is too complicated for you,,only visual check is enough..
I share you my tricks and hope it helps..
Power on your TV turn off your lights..if you will see the light comes from the screen the problem is t-con..if no light the problem is inverter board (backlight) board
Hope it helps..
Don't forget to rate..
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Oct 23, 2012
SOURCE: bad T-con board on my vizio tv
You can easially do it yourself only takes a couple of minutes to replace the TCON you can get replacement TCONs from www.tvrepairworld.com
aaron
  • 5 Answers
  • Posted on Nov 06, 2014
SOURCE: Vizio e701i-a3 problem. When I turn it on the
Very good chance it could have bad diodes. You will have to take the back off your TV and check to see if any have bad soder or need to be replaced
2answers
55 inch Vizio smart tv no video
It sounds like you may have a problem with the video signal on your Vizio 55 inch flat screen TV. The fact that the TV turns on and has sound, but no video and vertical lines on the screen, suggests that there may be an issue with the video processing or display.
It could be a problem with the T-CON board, which is responsible for the video signal processing. It could also be a problem with the LCD panel itself.
It's also possible that there's an issue with the cable connecting the T-CON board to the LCD panel, or a problem with the software on the main board.
I recommend consulting the manual of the TV or contacting the manufacturer for further assistance. A professional technician should be able to diagnose and fix the problem.
It's also possible that the issue is with the mainboard or the T-CON board is not compatible with the TV. Thus, it's best to check the compatibility of the parts with the TV before installing it.
1helpful
TV half snow static, half perfect
The T-con board sounds like the most likely issue on your Vizio. Typically if the video signal is being sent to the T-con, then the t-con resolves it into the format required by the LCD screen. In this case since part of the video is fine and the part is snow/static, I would suspect the T-con. Is it perfectly half the screen? Typically there are two connectors out of the t-con to the LCD, so one if one of those is loose or going bad, then that may be the issue as well.
My Vizio p55-c1 tv wont turn on; need help with diagnosis. see details below.
Hi Alon, as you say, it would be very possible that the main board is responsible for the malfunction of your Vizio TV
Because you say you have no image, no sound, assuming you turn it on knowing what input it is and there is some ymagen and sound, but the TV does not show you anything
If you were to have sound, there could be the T-Con board, since this does not affect the audio
I hope you can solve the problem
Greetings Franco Dosil
Hola Alon, por lo que comentas, seria muy posible que la placa principal sea la responsable del mal funcionamiento de tu TV Vizio
Porque dices que no tienes ni imagen, ni sonido, suponiendo que lo enciendes sabiendo en que entrada esta y que ah? hay alguna imagen y sonido, pero el TV, no te muestra nada
Si llegaras a tener sonido, ah? podr?a ser la placa T-Con, ya que esta no afecta el audio
Espero puedas resolver el problema
Saludos Franco Dosil
Does Vizio e320vl has a T-con board if so where is it located?
I don't believe that sound goes into the T-Con board, so I think you are looking at the main board as a problem.
I have a VIZIO TV model E390i-A1, I have sound and have backlight but no picture. I have tried the flashlight on the screen at different angles and could not see a picture or menu.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. /
1helpful
What is wrong with my vizio 70" lcd tv?
About the only thing left is the main board if you got a good tcon replacement. Did you follow proper static procedures when handling the replacement board?
2answers
I replaced the T-con board on my Vizio TV, but I still don't have any picture, just sound. What else could it be?
Think something may have gotten unhooked when you put everything bacK together? Check out all connections and ribbons between boards for proper contact.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
