SOURCE: Connecting the hot water line to a new dishwasher.
use teflon tape on the elbow if you did the back it off put some more on it and stop when its snugged facing the right direction now ive torqued them things pretty tight my self they don't strip that easy
SOURCE: Spa water drains to pool
Here is a link to the Aqualink website so you can download a trouble shooting guide.
SOURCE: Carver cascade 2 No water at all comes out of the
Check the tank drain valve for water there.If you get a good water flow there you know the tank is getting water pressure.Check the first outlet downline from WH and if there is no water there you have a blockage or other problem.If you have to turn off water to tank, remove the outlet pipe ,and check for water flow from tank with in valve on.If no flow, tank is plugged up.
Hope this gets you going.
Testimonial: "Confirmed my diagnosis. Any idea how to get it unblocked?"
SOURCE: lay z spa water pump is faulty where can I get a
Hi Im Chris From BVL Elecric,
I cover Bournemouth and surrounding areas and supply solutions to most home electrical problems.
A lovely lady customer called me out today to diagnose faulty
LAY-Z-SPA
pump/heater that kept tripping the RCD.
After scouring the net and finding this same problem over and over again but no solution,I decided to get personal with the blighter!!!
RESULT:- problem solved,
Customer very happy,
no new parts fitted,
water heating fine now.
If you live in my coverage area,have a LAY-Z-SPA that is faulty,no or limited warranty then give me a ring and I will be only to happy to come on over and fix it for a small fee.
just think that dead spa/pool heater/pump could be heating your water again tomorrow and there is plenty of summer left to enjoy it.
You can find my details quite easily , just google BVL Electric Bournemouth
SOURCE: pool and spa heater will not turn on, low pressure on display
1) check the fuse on the transformer. You will get "low pressure" if the fuse is blown.
1a) remove front panel with flat head screw driver turning both big screws 1/4 turn clockwise
1b) look up under the 1 remaining front piece for 2 screws (one on each side). remove them and the 1 small panel slides down
1c) transform is directly in the center of this compartment
1d) red wire on transform has a black fuse case - twist open and check fuse (with an ohm meter it should read a dead short if it is working).
1e) if not working - replace with standard 250v 2a bus fuse.
2) it really is low pressure
2a) backwash pool or at least make sure pressure in filter take is not too high (high filter tank pressure == low water pressure in heater)
2b) if you have a bypass valve make sure it is not in bypass mode so most all pressure from the pump is going tothe heater
2c) right next to the transformer is the pressure switch. It has a small copper tube attached to the back and 2 wires in the front. Put an ohm meter across the two leads on this device. With the filter off it should be open, with the filter on it should be closed (short). If not either the copper tubing is clogged, the switch is faulty, or there is not enough water going through the heater. The amount of water that goes into the heater is adjustable and the water pressure switch is also adjustable. The owners manual explains how to adjust both but neither should need adjustment unless you have a special configuration (explained in the manual).
