Question about Samsung Washing Machines
My Samsung eco bubble washing machine displays Fe Error every week. What should I do to fix it.. Help
6ya staff
SOURCE:
Anonymous
SOURCE: Samsung Washing machine fault
I have foud a solution 4E error for my Samsung WD7101CKW. Water that comes inside washer is splitted in splitter with valves. One of these valves has a red label on it - this is a valve with restrictor of flow inside. This restrictor is used to limit flow speed mainly for testing purposes of pressure/water level sensor. Because of that restrictor (red cap with two holes of 0,5 mm diameter) blocked flow too much, after some time washer controller thinks that water has too low pressure.
Unplug washer, disassemble hoses from valves, disassemble valves from the washer (screwdriver needed), drill both holes in red restrictor to 1 mm (use 1 mm drill or just big needle). Assemble in reverse. Will work :)
Greetings - Thomas
Posted on Apr 17, 2008
Anonymous
  • 373 Answers
SOURCE: washing machine displaying E90 error
an E90 fault is a problem relating to the main control module found behind the front facia. it could just be a bad connection on the board connections though
Posted on Dec 13, 2008
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: instruction manual for a beko 1512s eco care washing machine
CLICK HERE
http://www.miaudioaddiction.com/fixya/manual.pdf
Please download asap - as it is stored on my personal FTP site, and will be removed in 48 hours.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Head over to the manufacturer's website.
Typically they have a SUPPORT section - where you enter the FULL model number, and then can download a FREE manual.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!
Posted on Sep 16, 2010
richroth
Richard Roth
  • 9472 Answers
SOURCE: I have a samsung washing
WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
Posted on Dec 11, 2010
john_cross
  • 6277 Answers
SOURCE: getting FE error on our
I suspect that stands for 'Filter Error' so I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 19, 2011
Testimonial: "I can only say a big Thank You for your kind help and prompt assiistance..it s a flter problem and cleared it off..back to working..Thanks a ton John."
What is the problem if the red padlock sign is flashing
Child lock is probably on. Press and hold the start button.
May 29, 2018 | Samsung Washing Machines
I have a samsung eco bubble washing machine and the softener is not going through
Look at the delivery tube and see if it's caked solid with dried softener. If so, flush it out with water.
Apr 09, 2017 | Samsung Washing Machines
Samsung eco bubble washing machine won't switch on and it's only 8 day old!!!!!!
contact Samsung directly or thru where it was purchased .WARRANTY
Oct 16, 2016 | Samsung Washing Machines
Eco bubble WF1124XAC. What does water sensor error (IE error code) mean?
google Samsung washing machine error codes for a list of codes and solutions.
Sep 08, 2015 | Samsung Washing Machines
New Samsung 8kg washing machine won't spin during calibration mode
Hi, our eco bubble 2013 model stopped working yesterday, we've tried the calibration mode but it doesn't get past the clockwise motion when doing this, can you please help?
Aug 14, 2013 | Washing Machines
Error codes
We have an instruction manual but there are no codes.
Apr 15, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
29 people viewed this question
Top Samsung Washing Machines Experts
Paul
Eric Rotmil
Eric Rotmil
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
