Please understand that you are talking to regular people who offer advice, not to the company that made your thing. Contact the manufacturer directly for support. If it is under a year old it should be under warranty
Please, Please people do NOT post your private contact information or account numbers here in public, especially on a site full of criminal fake tech support call centres.
SOURCE: how do I take my zeepad 7drk off demo
On your home screen tap the the app button,then tap the screen saver app. Tap Enable Screensaver to turn the screensaver mode on or off. Then remove the check to "service enable" check box.
Testimonial: "on the app button, I cannot find screensaver"
Hi, Zeepads have an issue with powering on....when charging it is best to use the mains charging as it is more powerful....if you are sure they have been fully charged then try this:
Hold the power button down for about 2-3 minutes.
Listen for a small click.
Take finger off of power button and wait for about 30 seconds.
Hit the power button again.
Hopefully you should see the start up screen, post back with the results!
Testimonial: "Held the button for a full 3+ mins., nothing. Not sure what you mean by using the mains charging, could you please explain. Can this tablet be charged using a USB cable?"
On my 7" zeepad I had to do a factory reset via usb cable and my pc and with software downloaded from internet. Please try these files " https://isohunt.to/torrent_details/13189077/zeepad-info-Isohunt-to#torrent_details " If you have problems burn files to a disk and bring tablet and disk to computer savy tech like a cell phone repair shop.
This is a 2-year old question, but you can pop the case open with your fingernails easily enough, and maybe re-position the little plastic switch button if it's in the case. It has a tiny loop on it, meant to line it up in position with a tiny projection on the plastic case. It seems that a spot of glue or threadlock on that loop might help it stay in place. If the little switch button is lost, you could reach into the slot and press gently on the switch (mounted on the circuit board) with a toothpick or paperclip. If you open the case, you'll see where it is, and what is involved.
