Question about Panasonic Televison & Video
I have a panasonic plasma tc-p55vt60 and it does not turn on anymore. I change the power supply and still nothing, how to test the poser ?
    Top Expert:
  • Panasonic Master
  • 76,204 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Nov 14, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: 42 plasma panasonic
DUDEEE this exact same problem happened to me!!!! what happened was it was workin fine then it started turning on and off, then now it goes through these weird phases where i cant turn it off using remote or the power button. every button on the side of the tv and the remote doesnt work. so i have to unplug it to turn it off, what a messedup problem!!! im taking my LG 32LB9D to the tv shop tomorrow i hope to get it assest and possibly fix, ill tell u how to solve the problem if my tv is fixed. :)
Posted on Nov 02, 2008
phil_frye
Philip Frye
  • 295 Answers
SOURCE: Panasonic plasma 50PZ85 power led blink 10 times
Either a bad power supply or a bad processor board.
A Good Service Shop should know what the 10 blinks are indicating.
May be a repair cost between $200 and 400 dollars.
Be prepared -
Blessings,
A/V Media Guy
Posted on Nov 22, 2009
owenskp
  • 12 Answers
SOURCE: Panasonic TC-P54G25 plasma hdtv won't
Perhaps an easy fix. Remove the back of the flat screen. There will be a main circuit board visible. There will be several capacitors, cylinders with a cross hatch on the silver top. Do any of them look like they have a dimple created by expansion of the internal capacitor material over heating? If you see an expanded top...that's probably your problem. Get your solder gun out and replace that capacitor. You can order a new one off of Amazon. If yours is a 10 volt capacitor, consider replacing it with a 16 volt unit. Generally the electronics companies under design the size of these units. When you replace the capacitor take note of the silver band on the unit and where its placed in the two socket holes....there is a positive and negative hole placement.
Posted on Jan 03, 2011
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: Panasonic TC-P42G15, plasma flat screen
Please check these 3 boards for blown fuses, bad caps, blown/shorted components.
Power supply, Y-SUSTAIN, and Z-SUSTAIN board.
You should download any one of the PLASMA TV training manuals to learn how PLASMA TV works from the link below, it will help you to get more understanding.
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Posted on Jan 15, 2011
elchamacodj
SOURCE: i have a panasonic 50 inch tc-50px24 plasma tv. i
blinkin de red led tv panasonic plasma
Posted on Feb 13, 2011
PANASONIC PLASMA TV- TC-P50G10-03/09-MD90690706 NO PICTURE
Could be an open internal fuse or power supply failure
Jul 13, 2017 | Panasonic Televison & Video
Hello, lighting hit and my plasma Panasonic tc-42px24 will not turn on. completly dead. was told it maight be supply board??? thanks
Power surges wreck havoc with power supplies since they are first in line and bear the brunt of the rushing power. Try replacing the power supply board on the cheap by getting a used one on ebay to minimize the expenditure in case that is not it. Always a possibility,
Sep 09, 2015 | Panasonic Tc-42px24 42 in. Plasma TV
Panasonic Plasma TC-P42C1 10 light blink code, then the light came on and then no light at all-nothing! Power Suppy board?
By blinking led its shows where is exactly the complaint. You have to count the blinking. How much time its blinks in one sequence. the only it will be possible to say is it power supply or any other boards.
www.electro-medical.blogspot.com
Sep 03, 2015 | Panasonic Televison & Video
My Panasonic 50" plasma hd tv TC-P50X3 shows no power. There is no red light blinking. Wahat can I do to fix the problem
Check your stand by voltage on main board and power supply cable..should see marking on PS for Stby 5v. I you have the 5v change main board or A board it is not supplying your voltage back to PS to turn on. If you dont have 5v stand by change PS.
Apr 04, 2014 | Panasonic 50 TCP50X3 50 Plasma TV
Panasonic TC-42PX14 wont turn on power light flashes 1 time
You may want to shop for that board or at least consider removal of the HDMI socket in question---tested for shorts there I presume?
Nov 05, 2012 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
I turned on power and red light is blinking but tv does not come on - red light just blinking no power/picture Panasonic TC-54PS14
Tries unplug,replug the tv back like an hour later.The tv now,should resetting itself back to the factory setting.The tv should work now.Not,than the tv power supply board have problems,not giving the tv it wright voltages anymore.The tv power supply board that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 06, 2010 | Panasonic TC-54PS14 54" HDTV Plasma TV
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
