FIXYA does not sell parts.
Use the internet to search, or visit retail stores that carry that model to request assistance.
Part number or at least model number is needed to search using Google.com
Possibly available thru Home Depot, Walmart, online at Amazon.com, or www.repairclinic.com
https://www.repairclinic.com/PartDetail/Lid/WPW10193857/1456205?TLSID=1779&Ref=611198&gclid=CjwKCAiAzanuBRAZEiwA5yf4ulvClQ-c9bkG6bmkfD91ywohSLeEMqIxuQ4R7ziLpTtNgirJg3gcyxoCO7MQAvD_BwE
SOURCE: Kneading Blade for Magic Chef CBM 250-2
I found a compatible belt!!! It's a Dayco # 15260, which you can order from partstore.com!!
SOURCE: MAgic Chef top loading washer will not spin or drain
you have to open it,at the bottom of the drum it has a either clear or black plastic hose that goes to pump held together with pressure clips remove them water will flow then ,it also will flood the aerea around it,so plenty of soil to soak it up
SOURCE: my washing machine drains but does not spin
Look for a motor belt that is worn out and make sure that the drum turns freely (machine off).
SOURCE: MAGIC CHEF WASHER WONT SPIN OUT
underneath the washer is a pully assembly kit . remove the belt ,the c clip and replace the pully kit about $ 20.00 cost for parts.
SOURCE: ovens not lighting magic chef
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
wwt
