Question about GE Washing Machines
My GE Model PTWN8050M0WW won't spin. When turned on, and trying to agitate, it sounds like it is skipping gears.
And when the machine is turned off, instead of not being able to manually turn the agitator, it easily spins around. Suggestions on what could be wrong and how to fix it?
  • CJ Odom
    CJ Odom Nov 14, 2019
    Thank you! The link to the part on amazon.com did not show up. I tried to watch the video from YouTube you posted, but my machine is different. It doesn’t have the tall agitator in the middle, it’s circular and is even with the bottom of the metal interior of the washing machine. Looks like this:https://www.reliableparts.com/thumbnail/...
    Thanks!
  • Ned Halaweh
    Ned Halaweh Nov 14, 2019
    Looks like the one you need is called a drive hub assembly. You pop the cap off and there's a bolt underneath. Should be straight forward.
  • 240 Answers
There's a part under the agitator that lifts off if you pull up from the bottom on both sides) called a coupler that is attached to the shaft with one bolt. The plastic teeth probably have stripped off from this coupler, causing the agitator to not agitate properly.
I would buy the part on amazon.
Here's the link to the exact part:
shorturl.at/oxDX0
Video to show how:
https://youtu.be/PN4Q-VqyReo
Posted on Nov 14, 2019
Testimonial: "Thank you! Is there a specific store or website you recommend purchasing the coupler from?"
  • CJ Odom
    And what type of tool do you suggest using to take the agitator out of the bottom of the washer?
  • Ned Halaweh
    The agitator should just be pulled off with both hands.
    shorturl.at/oxDX0
    Video to show how:
6ya staff
SOURCE:
Vidrich
SOURCE: GE WBXR2060V1WW won't agitate...
There's a part under the agitator(which lifts off if you pull up from the bottom evenly on two sides) called the "Air Bell Coupler" that attaches to a metal toothed motor shaft with one bolt. More than likely the plastic teeth have stripped off from this coupler, preventing it from sitting tightly on the shaft, thus causing the agitator to not "agitate" properly. You can get this from www.partselect.com. PS1517844 KIT - AGITATOR COUPLING
Cost is $7.15 plus shipping.
Posted on May 06, 2008
kram26
Mark Milan silaran
  • 544 Answers
SOURCE: washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Posted on Mar 29, 2009
Anonymous
SOURCE: GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Posted on Apr 15, 2009
jimorris77
  • 411 Answers
SOURCE: GE washer model WJRR4170E1WW won't spin or agitate
.I am not a repair professional. I am a 78 year old man
who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and found that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer or a front load washer I suggest you go to www.applianceaid.com where they have very good step by step trouble shooting and repair information on washers and dryers as well as other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at www.acmehowto.com You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to www.applianceaid.com where they have very good
trouble shooting and repair nformation on most
washers and dryers. I think you'll find what you need
there. Don't worry about the timer, they hardly ever
go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Posted on Dec 02, 2009
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: Won"t spin or agitate. Makes a loud rattling noise
If this is a Whirlpool manufactured TOP LOADER (such as Roper, Estate, Kenmore, Amana, and Frigidaire), you may have a damaged or broken motor coupling. Whirlpool manufactured top loading washers use a motor coupling between the drive motor and gearcase (transmission) in place of a drive belt. This configuration is known as "direct-drive". The coupling can break through normal wear and tear. Washing frequent loads of heavy items and reduce the life span of the coupler. Common symptoms include the following:
1. No spin or agitation.
2. Washer will fill and empty.
3. Drive motor still runs.
4. Strange rattling, grinding or clicking noise during agitation or spin cycles as the drum sits still.
If your washer is exhibiting these symptoms, then its probably a safe bet that the motor coupling is bad.
The following link explains how to replace one:
http://www.fixya.com/support/r3574231-replacing_a_motor_coupling
The part number for a replacement motor coupling is inlcuded in the link I provided. Replacements can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I have listed also included helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need.
If you have any questions, please post back with your complete MODEL NUMBER (located on a nameplate along the wash tub rim under the lid) and let me know. I hope this helps you.
Posted on Dec 17, 2010
GE super Capacity model#WVSR1060G3WW my washer will not agitate/ wash no matter what setting I have it on. It will however spin.
First, I'm not a General Electric Technician.
* Gear drive agitator not working or gears broken (you may hear the motor 'spin' on and off as it tries to agitate.
* Check your warranty (they can go from 3 to 5 years or even longer if you have extended service)
* Call your vendor (brand) for service.
*** the following is for information only ***
https://www.youtube.com/watch?v=D0FGSAOJdlo
https://www.youtube.com/watch?v=II_p8j-RSWU
https://www.youtube.com/watch?v=GA98ZmnzEfc
Aloha, ukeboy57
Jun 06, 2018 | GE Washing Machines
It barley spins
could be tranny if noisy. may be worn dawgs (gear cogs) found inside the agitator. Remove cap and they'll lift out Order by model number
I’m happy to assist further over the phone at https://www.6ya.com/expert/howard_977676954994c5b2
Mar 15, 2016 | GE WHDRR418GWW 35 cu. ft. Washer
Ge top load washer won't agitate or spin after
what is your model number is then we can started then okay
Sep 15, 2011 | GE Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Tub will spin but agitator won't move on my ge washer model wpsr3090v0ww
IF it sounds like it is agitating but isn't moving, check to be sure the agitator is still firmly bolted to the transmission shaft. If it sounds like it's stuck when it tries to agitate (belt slipping possibly, etc.) it is probably a bad transmission and often not worth repairing unless you can find a used one somewhere.
Dec 31, 2009 | GE WBSR3140DW Top Load Washer
I have a GE Profile Prodigy top load washing machine. Sometimes the spin cycle does not spin, sometimes it spins. It makes a clicking noise during gentle cycle
The gears maybe going out. Sometimes it is able to engage in the other direction which the spin, sometimes not. Washing machine have complex gears that in one way agitator works, and the other the gear locks to turn the whole tub. The clicking noise is probably the locking mechanism in the gears that has caused the whole intermittent problem.
Jul 01, 2009 | GE Profile Prodigy WPSE4200A
Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
Washing Machines Logo
244 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
