Question about Mitsubishi Televison & Video
My mitsubishi 60 turns off aftr 10 minuts when i turn on
    Top Expert:
  • Mitsubishi Master
  • 65,422 Answers
CHANGE THE SLEEP TIMER TO 0
Posted on Dec 10, 2019
6ya staff
SOURCE:
Anonymous
  • 6 Answers
SOURCE: tv turns off and then back on
as the anwer to the customer with the short lamp live you must replace the lamp but first make sure your tv fans ar not cloged & replaced if needed other wise your lam life will be reduced dramatically
Posted on Dec 10, 2008
localwonder
Michael Masters
  • 6784 Answers
SOURCE: dryer will only run for 10 minutes at a time
Hi, this is heat related. the timer module on this unit is overheating, in return, it is shutting down due to the heat generated but the faulty timer circuits. you will need to replace the timer device asap.
Posted on May 27, 2009
Doug Warne
  • 55 Answers
SOURCE: Television turns itself off after being on for about 10 minutes
Run the diaginostic that you find in the pdf user manuel...1st
Posted on Dec 16, 2009
TCC
  • 15 Answers
SOURCE: My samsung syncmaster 73nw,when i
You have bad Capacitors on the power inverter section; These 1000 uF 10V& 470uF 16V Caps will function half blown. As soon as they warm up the Cap either opens or shorts and takes down the power inverter. The venting on this monitor is very poor; To verify take a fan and place it behind the monitor, then try it again. If the monitor runs longer you have verified your problem. TCC
Posted on Feb 02, 2011
Don Cahala
  • 239 Answers
SOURCE: 99 300m wont shift out
Memo-
Sensors and trans codes.
Posted on Dec 12, 2011
Replaced lamp on mitsubishi wd62527 worked for 10 minutes then shut down. Now red lamp light is on
If the red indicator light on the front of your HDTV is glowing a solid red, you should first unplug the AC cord from the wall power outlet and wait for 60 seconds before reapplying power to the HDTV.
After you turn the TV on, if it doesn't power up, try holding the power button down for at least 8 seconds. That's supposed to force a system reset. If your model has a system reset button, use that instead. Press the reset button for about 20 seconds...release it and press it again for 20 seconds, release it again and the led will blink just for a minute or two. You should now be able to turn the TV on.
If after several attempts, the HDTV has not fully powered on and the LED on the front of the HDTV is still glowing solid red, you may want to reseat the lamp.
If reseating the lamp has not resolved the issue then your next step is to order a replacement lamp.
Apr 05, 2015 | Mitsubishi Televison & Video
Mitsubishi vs 60707
pleaser eset you TV as below.
Turn off and remove the power cord from the main socket.
leave it for about 30 min
turn back on again.
please make sure your sleep mode is off.
May 19, 2008 | Mitsubishi VS-60707 60" Rear Projection...
WD60C9 turns off for a few seconds
It is possible since the set intakes air from front and exhausts it from the rear you have a dirt buildup inside.
http://www.fixya.com/support/t12296849-turns_off_shortly_after_turn?mt_f=viewFull162
Apr 30, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
Nov 11, 2009 | Mitsubishi VS-60705 60" Rear Projection...
Pioneer SD-P62A3 62" shuts off - won't stay on
If this TV turns back only when it is cooled down than it has cold solder joints tha have to be resolderd.
Jul 07, 2009 | Mitsubishi VS-6055 60" Rear Projection...
Mitsubishi VS-6071 60" Rear Projection TV Problem
can you give me the number of the manufacture of a 60in mitsubishi VS-60707
Oct 25, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Need anwsers asap! Mitsubishi VS-60719 60 in
Can you psot a picture of what the lines look like and I will try and help you out with it. Please reply to this same post each time. Thanks
Aug 06, 2008 | Mitsubishi VS-60719 60" Rear Projection...
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
