Water Heaters Logo
L
Lorraine Terka Posted on Nov 17, 2019
How do i reset my boss therm
No hot water or heating
alfonzo nonoy
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
Problem Solver:
  • Contributor 5 Answers
  • Posted on Dec 05, 2019
alfonzo nonoy
Contributor
Level 1:
Welcome Back:
Problem Solver:
Answers
5
Questions
0
Helped
2374
Points
12
Some heaters are there's and indicator of reset button on the unit..and some are located inside the unit can be push by using screwdriver.
My bocsh 830es water heater will be running normal then will kick into a A3 mode no more hot water
Check for a green wire near the top right of your machine. It would loop back to itself with a little black heat shrink on it. This should be far away from the heat exchanger. if its near it, I would recommend pulling it out of the wire clips, and relocating it to behind the control unit on the right side of the machine. Keep it away from heat....its a resistor, and will pop random A3 codes if the heat increases its resistance. Reset your code and you'll be good to go.
I'm getting an er3 reading on my water heater tank , what does that mean
It tells you that your water heater called for heat for more than an hr and never got hot enough to meet the demand.
CAUSES
-bad sensors
-no hot water from boiler
-bad thermal transfer
-low delta T across water heater
Armitrol boiler mate hot water maker has code er3 and we have not hot water. can u tell us what that code means?
It tells you that your water heater called for heat for more than an hr and never got hot enough to meet the demand. multiple scenarios can cause this
CAUSES
-bad sensors
I have a ER3 message. How can I fix this
CAUSES
-bad sensors
8helpful
ER3 no hot water
Er3 means that the water is being heated for more than 1 hour without reaching the set temperature.
Need new aquastat.
Caluclation
This requires a little math....
BTU - amount of heat it takes to raise one pound of water 1 degree F.
I gallon of water = about 8.54 pounds
91 gallons of water = about 777 pounds = 777 pounds x 70 degree rise = 54,390 BTU.
1 Therm (what the gas company measuers in) is 100,000 btus
1 therm costs about $.45 (45 cents) depending on where you are
54,390/100,000 x $.45 = about $.25 per hour
This cost can vary somewhat depending on the inlet water temperature, gas cost, and the efficiency of the hot water heater
Water not getting hot
You seem to have a burned out heater elemt. Most water heaters have 2 e.ements. If the upper one bruns out, it will not heat at all. If you have a cheap heater built by State, you probably have a bad lower thermostat. It will over heat and trip the protection device. If you reset the red button on the upper thermostat and it gets too hot (check in about 2 hours) then replace the lower therm. You could still have a burned out upper element.
Top Water Heaters Experts
vince
Steve Sweetleaf
Steve Sweetleaf
Are you a Water Heater Expert? Answer questions, earn points and help others
