Question about Juki Sewing Machines
Juki bobbin rattles while sewing - Juki Sewing Machines
6ya staff
SOURCE:
yalmer
Hjalmer Lamminen
  • 552 Answers
SOURCE: threading a juki ddl 5530
Go to this link and you will find how to thread your machine.
Posted on Apr 02, 2008
rylee_smith
Rylee Smith
  • 8619 Answers
SOURCE: my Juki DL 5555 won't pick up bobbin thread
It is possible that you have the bobbin in backwards. Try inserting the bobbin so that the thread pulls in the opposite direction than it currently does. Also, sometimes you have to really push the bobbin case in to make sure it snaps into place. Other than that, you may have a dull needle...try replacing it, or it just may need an overhaul.
Posted on Jan 30, 2009
sewtexas
  • 136 Answers
SOURCE: Singer 4622 drop in bobbin rattles
Recheck top threading
Posted on Jul 07, 2009
clairejemima
SOURCE: I just bought a used juki DDL 8500 industrial
I just bought the same machine and mine came with a photocopied manual. There is indeed a bobbin winder on the side, there's a flat section on the side of the bobbin winder closest to you, if you push that forward it connects a wheel attached to a bobbin spoke, to the belt that runs between the machine and the motor. To wind the bobbin, put the bobbin on sideways onto the axis of the wheel that is on the inside of the machine, and push the bobbin winder forward.
If you're looking for where the bobbin case is located on the machine, if you look underneath the machine on the left hand side, there should be a metal belly, on the left side of the belly is an opening, and in there sits the bobbin casing.
I think you were asking for either one of these answers, I'm on here troubleshooting for my Juki DDL-8500, good luck with yours, hopefully I can find what I need to know too!
Posted on Aug 06, 2010
marianne bags
  • 161 Answers
SOURCE: I recently purchased a Juki
perhaps you have the wrong needle or its not in the proper position?
Posted on Sep 12, 2010
My juki 2000 changes tension when I change bobbin thread
When you change thread, are you using the same brand of thread and thread weight? A heavier or lighter weight thread will affect the bobbin tension. Otherwise, perhaps the bobbin case is worn. Look for a replacement bobbin case.
http://www.sewvacdirect.com/juki-bobbin-case-fits-tl2000qi-tl2010q/
Jun 15, 2018 | Juki Sewing Machines
Manual needed for juki ddl 555 also need bobbins for this machine
go to the Juki website and ask them about a manual and bobbins
Mar 15, 2015 | Juki Sewing Machines
How do i use jean thread on my juki industrial sewing machine
are you using a denim needle for sewing jeans?
where is the thread getting caught up at?
make sure the bobbin is turned the right direction in the bobbin case
Feb 13, 2013 | Juki Sewing Machines
Juki DDL8700 Bobbin Winder Problem
the machine should be checked by a sewing machine technican
to see what wrong with the bobbin winder, the assembly may need
to be replaced
Dec 20, 2012 | Juki DDL-8700
Juki ddl 8700 my machine was sewing fine I put in a heavier (jean) thread. Now it wont pick up the bobbin thread to sew at all? Help?
try changing the needle to one that will work with heavier thread
you may have to change the bobbin to heavier thread also
try adjusting the tension also
Sep 25, 2012 | Juki DDL-8700
I have a juki tl98q sewing machine for my mid arm. The bottom thread keeps bunching up and I cannot sew anymore. What can I do to fix this? Do you have a diagram to thread the bottom bobbin and the top of...
The threading diagrams are available in the manual which is available from Juki on the TL-98Q product page: http://www.juki.co.jp/household_en/pism/tl98q.html . The direct link to the manual is http://www.juki.co.jp/household_en/pism/img/tl98q/download/98qim.pdf . See pages 14-18 (pages 16-21 of the PDF).
There are a couple of things I recommend that you check. First, make sure that the bobbin is evenly wound. This is a function of the bobbin winder tension; see the manual (page 15) for that adjustment. Next, check if the bobbin case tension is correct. Place the bobbin in the bobbin case and dangle the unit from the thread. Try to shake the bobbin case up and down, sort of like a yo-yo. The thread should advance by a bit. If the thread length doesn't change, loosen the set screw on the side of the bobbin case a small amount. If you get a really long tail of thread, tighten the set screw. See page 21 of the manual.
Next check for any loose threads and dirt in the housing around the bobbin case. Depending on the length of time that you have been using the needle, replace the needle.
I hope this helps.
Sep 28, 2017 | Juki TL-98Q
How do you wind a bobbin on a juki 1541s ??? This is a brand new machine to me and I can't figure out how to disable the needle head and wind the bobbin
Here are two websites that might be of help to you. If you just go to the www.westchestersewing.com they have a "contact us" box and you can send them your question.
http://www.westchestersewing.com/juki/dnu1541/
http://industrial-sewing-machines.com/sewmach/mach_detail.asp?brand=Juki
Sep 10, 2010 | Juki DNU-1541 Mechanical Sewing Machine
I have a juki sewing machine and the nittle
the problem of your juki sewing machine is your bobbin. adjust your bobbin to the right place.
Feb 16, 2010 | Juki MO-655 Mechanical Sewing Machine
My Juki DL 5555 won't pick up bobbin thread
Jan 23, 2009 | Juki DDL-8300
Sewing Machines Logo
21 people viewed this question
Top Juki Sewing Machines Experts
TCHNICAL SUPPORT FOR...
Wayne Buss
Douglas Plant
Douglas Plant
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
