Question about RCA Televison & Video
I have a rca projection tv model # p52731wk will not power on and has no light
    Top Expert:
  • RCA Master
  • 54,831 Answers
Open internal fuse or power supply failure
Posted on Nov 27, 2019
6ya staff
SOURCE:
Vista Electronics
  • 1694 Answers
SOURCE: Clicking sound coming from my projection TV RCA Model P46921 year 2000
Bad Flyback xformer = P46921YX1 Part # 239111
P46921YX4 Part # 250694.....................................T.
Posted on Dec 21, 2007
Lashawn Robinson
  • 1153 Answers
SOURCE: RCA PROJECTION TV MODEL # P46731AT
A short in the PS. Does it blows as soon as you plug in or when you hit power? It makes a different. For more info ctechnicians.com
Posted on Jan 07, 2008
Anonymous
  • 19 Answers
SOURCE: rca projection tv has no picture or osd
Check the bulbs. If one is burned out, you will get this problem. The bulb is easy to change but will run you about $300.
Posted on Feb 10, 2008
Ronnie Houston
  • 2920 Answers
SOURCE: Flashing green power light on TV
have the power supply checked out sounds like it went out
Posted on Aug 26, 2008
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: model d52w19 rca projection tv,will not turn
Thats the eroor for the flyback and CP150 needing replacement you can get the flyback # 259296 and the CP150 at the following link and they give free step by step instructions on how to do the repair.
http://servicemanuals.vstore.ca/
Posted on Mar 06, 2009
Rca p52731wk convergence issues
e089e5b2-9394-4ed6-9a51-c32a90d091bc.jpgWhat you describe is known as a convergence board problem. Its a fairly common problem. You can read more about it herein this Fixya Tip.
http://www.fixya.com/support/r4581251-convergence_failure_test
Feb 22, 2013 | RCA Televison & Video
I have model RCS P52731wk. No power when i puch the power button on the front. Is there an internal fuse?
THERE IS A FUSE, it is located inside where the power cord connects.
Let me ask does power light come on for just a moment at all?
SD TECH
Nov 03, 2010 | RCA P52960 52" Rear Projection Television
Is there a reset button for rca tv model p52731wk
You can try a hard reset with this model. It requires unplugging it and leaving it unplugged for at least four hours. There are numerous set codes for this model, but it all depends upon the problem you are experiencing. There is no singular "reset button," though, as the system was simply too complex in its day to warrant one.
May 09, 2010 | Televison & Video
I have an rca projection tv model #p52960. when i
NO HORIZONTAL DEFLECTION. THIS RUNS THE REST OF THE SET. POSSIBLE COMPONENT FAILURE/BAD CONNECTION
Dec 26, 2009 | Televison & Video
My RCA 52 blinking power light, no picutre
Flyback transfromer is defective and needs to be replaced.
Oct 12, 2009 | RCA HD52W56 52" Rear Projection HDTV
RCA P52731WK REAR PROJECTION NO RED ON SCREEN
The RCA model is a 3 CRT projection TV. Most probably you need a new RED CRT, or there is a problem with the R(ed) channel (the picture is made up of 3 component colors: Red, Green and Blue). No way of telling without testing of the projector. Sorry!
Jul 11, 2009 | RCA P52926 52" Rear Projection Television
My T.V. won't come on.
I would guess that the HV Block has failed. A very common failure. I would hesitate trying to replace it unless you are familiar with Projection HV circuits. You did good supplying
the Model # and Chassi #. both are required to get the proper part# if you try to get the part yourself or calling a service shop to fix it.
Hope this helps,
Skyassoc
Jun 22, 2009 | RCA P52926 52" Rear Projection Television
I have a 1994 RCA projector TV model# p52731wk. The picture is all blue. How do I change the bulbs?
Unless you have a source for the tubes then I can help, however, those tubes have not been available for over 4 years now. I recommend start looking into a new one or see if you can locate a refurbished projection set from your local Television Repair Center.
Apr 23, 2009 | Televison & Video
Rca p52731wk wont power on
check for bad or broken connections around the high voltage transformer......
Feb 24, 2009 | RCA P52960 52" Rear Projection Television
My rca p52731wk projection television will not power on
We are available for conference Today and Everyday. Wewill assist you in repairing your set. The Part you need is Transformer 226094. Please joinin conference for part price and location
LOGIN
Circuitcity
Dec 26, 2008 | RCA P52960 52" Rear Projection Television
Televison & Video Logo
24 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
