Question about Maytag Dryers
LDG4000AAW Maytag Dryer making clunking noise
    Top Expert:
  • Maytag Master
  • 65,443 Answers
Check the drum support rollers
Posted on Nov 23, 2019
6ya staff
SOURCE:
David Coomer
  • 1073 Answers
SOURCE: Maytag Dryer Squeaking noise when first turning it on
nedd to replace the rear tub rollers
Posted on Apr 21, 2008
Richard Lew
  • 489 Answers
SOURCE: clunking noise
The clunking noise may be a broken weld on the drum.  Every time it turns and passes through the guide wheel supports, it makes a thunk thunk noise.  You will need to have a qualified LG technician diagnose the problem correctly but that's what it sounds like.
Posted on Jun 11, 2008
James Chandler
  • 686 Answers
SOURCE: dryer makes clunking noise
change your drum rollers
Posted on Mar 12, 2009
Anonymous
SOURCE: Maytag Dryer clunking noise
may 26 2009
My maytag dryer is making a very loud squelling sounds in some of it cycles. still drying ok
gmalcom
Posted on May 26, 2009
sandysummer
  • 14 Answers
SOURCE: Maytag electric dryer is making a high pitched noise
Maybe your problem is coming from the bushing shaft part. Mine was so used that it made a terrible and high pitched sound.
Try to look behind your machine, remove the part hidding the bushing shaft and check if everything is ok.
My bushing shaft was make of metal, and I replaced it with a teflon one. Everything is working fine right now.
Have a good day.
Posted on Sep 13, 2010
I have a loud noise coming from the bottom right side of my dryer. I am trying to figure out how to open the cabinet up to see what the actual problem is but I can not tell how to open it. There seems to...
maybe the drum rollers,Tim:
http://www.partselect.com/dryer+maytag-atlantis-drum-removal+repair.htm
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
May 29, 2011 | Maytag PYE2300AY Electric Dryer
My dryer (maytag atlantis) has started making a loud clunking noise with each revolution. its still drying fine but sounds terrible. any thoughts?
A loose belt will allow the drum to slip when clothes hit the paddles in the drum. It sometimes sounds like a pair of tennis shoes are in the dryer when it slips and is usually rythymic.
These machines also use drum rollers that can make a racket when they go bad.
http://www.repairclinic.com/Maytag-Dryer-Parts
Good luck.
Mar 02, 2011 | Maytag Dryers
My gas dryer works but makes a clunking noise when I press srart
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 26, 2010 | Maytag Dryers
Dryer makes clunking noise when it starts and stops. Also noisy during the drying cycle. It's a Maytag
May need a new blower wheel.
The wheel is mounted to the motor and if it is stripped out it will not move air past the heat element.
Have it checked before the heat element fails.
Jan 16, 2010 | LG DLE2515S Gas Dryer
Clunking noise, like a tennis shoe, top right rear of dryer
HI sounds to me like your drum support is worn, it would make a thumping sound. You have 2 you should replace them both.
If you are needing a part - call this toll free number 1 877-489-5610, I have used them many times, they are the best. Best of all overnight shipping!
Sep 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag SD-8 about 10 years old. Making clunking
The reason to this problem is due to the bearing.
Sep 02, 2009 | Maytag PYE2300AY Electric Dryer
Sounds like you need a blower wheel.you will need to remove the front panel and the houseing under the front panel.It is located on the bottom front laft side. if you need help on assembly or disassembly let me know hope i fixya :)
May 20, 2009 | Dryers
Clunking grinding sound
It sound like there is change or hard object in the inner dryer tumbler fins Not sure what model or make the dryer is need more info please.Maytag inglis??????
May 07, 2009 | Dryers
Dryers Logo
41 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
