Question about Maytag Dryers
Maytag Neptune dryer is not heating, where should I start in terms of diagnosing this issue
    Diehard:
    Visited the website for 60 consecutive days.
  • 330 Answers
Check the igniter it should glow when turned on
Posted on Dec 06, 2019
6ya staff
SOURCE:
Krazytech
Franklin Ouchida
  • 725 Answers
SOURCE: maytag neptune dryer.
check ingitor see it it glows red hot then check flames sensor and or gas solenoids
Posted on Aug 26, 2007
SOURCE: maytag neptune dryer MD6
All you need to do is check the element for continuity with an ohm meter, if it has continuity the element is good. The dryer also will run on 110 volts of power but it needs 220 volts too run the element, so check and make sure all the conections on your cord are secure and that you have 220 at your wall outlet.
Posted on Jun 12, 2008
milten1
milten1
  • 1304 Answers
SOURCE: Maytag Neptune Dryer Won't Heat up
these particular dryers have issues with the heat coils,
it probably has a bad element
Posted on Oct 03, 2009
Anonymous
  • 230 Answers
SOURCE: dryer does not heat up.
Hello there:
normally on these units if the dryer was working ok and then suyddenly stopped heating your heating element or the ignitor (excitor ) has failed and is need of replacement
so i would start by having these things checked first by contacting a local repair man to do a evaluation on the unit and if kyou still have a valid warranty i would use it ok
I hope that this is very helpful for you
Best regards Richard
Posted on Nov 16, 2009
Mukesh Kumar
  • 3230 Answers
SOURCE: my dryer runs but no
Well if your dryer tumbles, but there is no heat then you may please check out the following -
1. First of all you can check out for proper air flow - Check the vent for proper air flow by placing your hand over the exterior vent while the dryer is running. You should feel a strong flow of air. If not then check the lint trap. It is located either on top of the dryer or possibly just inside the door. Remove any lint that has built up in the lint trap. Cleaning the lint trap should be done regularly, even as often as after every load. Do not operate the dryer without a lint trap in place.
2. Secondly you can check out the Ignitor - gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes. Post comments for further help or information.....
Good Luck!!
Thanks for using FixYa!!
Posted on Sep 22, 2010
I would like to find out if my Maytag Neptune dryer has heat coils or just a Flame sensor
Go to YouTube and type in - Maytag Dryer heat coils and see if it comes up. Also type in Maytag Neptune Flame sensor on the next search.
Oct 05, 2015 | Maytag Dryers
I have a maytag neptune which is about five years old. It runs fine, but the dryer does not heat up. What should I do orcheck to diagnose problem?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 11, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Problem with the Maytag Neptune MDG6700A Gas Dryer WHEN STARTED HEATS UP THEN NO HEAT AT ALL. MAYTAG MDG6700AWW
Hello & Welcome to FixYa
When the dryer heats for few minutes and then it won't work it means that the thermostat is bad and needs replacement. This part is located on the blower wheel housing inside the duct, you can also check this part for continuity before replacing. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | Maytag Neptune MDG6700A Gas Dryer
I have a Maytag Neptune MDG5500AW that is not drying. It sometimes has heat but most of the time it does not. Can you help me diagnose the problem?
if it has heat the first 15 to 30 minutes and then no heat you have bad gas coils,they are located on the top of the gas valve,just remove the two phillips screws,remove the cover and change out the coils,
Aug 04, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Sep 30, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Neptune mdg3000aww starts heating and runs fine but stops heating shortly after start up can restart heater starts again and shuts down
If the machine keeps running but just not heating you have a thermostat issue. It could be the operating therm. or the high temp limit therm malfunctioning, shutting off the element.
If the machine stops running completely, check the door switch.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Control Panel frozen. Displaying "8.8." Cannot reset.
controls were somewhat an issue with these. but service manual can be found in the maytag library at servicematters.com it will detail method of entering diagnostic and reading codes. post results
May 01, 2009 | Maytag Neptune MDE5500AY Electric Dryer
MayTag Neptune MDG9700AW Gas Dryer
Check the lint tubing and also for lint underneath the dryer. There is a blockage somewhere for this to happen. This is a built in safety feature for gas dryers that others don't have.
Jun 01, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag gas dryer
I have the same issue. Runs but no heat.
Jan 13, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
46 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
