This happened to me. The computer will not work with the battery in it.
Solution: Take battery out and plug in without battery... It should work,
You will need to get a new battery
This can also indicate that the machine is hibernated and cannot wake up for some reason. You may be able to resolve this by holding the power switch on for about 6 seconds. The machine should then do a full shutdown and should then power on as normal.
Do you see your HDD light flashing? If not then this could be an indication of a HDD failure or a motherboard failure.
You will need to take the PC to a qualified repair center.
