Does the SD card read in a computer or other device? (Note: Make sure to cancel if it offers to reformat or initialize the card)
Does a different known-good SD card read in your Alcatel?
Sometimes cards just go bad. Sometimes phones and cameras erase or corrupt the cards. If there is irreplaceable data on it, look for SD card file recovery programs at reputable sites like C'Net Downloads.com or PCWorld
SOURCE: Kingston 4gb sd card won't read
I had a problem with lenovo's reader like this, because i put in the nokia 6600 card, correct format and all, but apparently too old and not yet ment to be read by a computer ...
sd could still be hc ... the system of names is still not set up right. if you got a small black attachment for the card that makes it longer, put it on and try inserting the card again.
check if all the drivers are like they should be.
if you've got a friend with a card reader, make sure the card is ok. and if you've got a friend with a card, make sure the reader is like it's supposed to be
post a feedback, ok
SOURCE: wont read my sd card it says card not ready
su500 will take ONLY San Disc or Kinston Micro up to ! Gb ,then will format,....U'r quiet welcome
SOURCE: wont read sd card 4 gb
If I am not mistaken, the Dash cannot accept anything larger than a 2GB card.
SOURCE: my phone wont read the micro sd card
Check wheteher the card is nor micro SDHC, you r device supports only SD cards , if its SDHC then your device wont ablt to read it
SOURCE: tomtom 1 v3 wont read new sd card help
Your model TomTom will not recignize a sd card larger than 2gb. You can do a search and replace the bootloader to a newer version so it will read up to a 16gb. card, but be careful the wrong bootloader will brick your TomTom and it is not reversable.
Testimonial: "your help was spot on "
