Can you remove the ink from the printer then power it off.
then using a Q-Tip with cleaning alcohol (or warm water if you do not have any), clean out the areas where the ink goes in.
Then use a damp cloth and wipe down the inside of the printer.
Once done, let it dry for 10 minutes
Then put the ink back in, power it on and tell me if it then prints correctly please
This will also allow you to see if any foreign objects are in the printer which may cause this.
Testimonial: "tried cleanning all printer heads with alcohol i even replaced the ink still get error code 5207"
SOURCE: canon ir-2020 error code e197
check code here
http://www.startcopy.net/defects/ir2016_2020.shtml
SOURCE: Canon imageRUNNER 2020 error E007. What is the
An error in the rotation of the fixing film is detected.
The reading of the main thermistor is 100°C or higher and, in addition, the fixing film sensor does not detect the rotation of the film for 6 sec or more
while the fixing motor is driven.
I think - The fixing film sensor is faulty.
Caution To clear the error, execute the following in service mode:
COPIER>FUNCTION>CLEAR>ERR.
SOURCE: Canon imageRUNNER 2020 alternates between displaying Error Code E019 and saying "Waste Toner Full".
hi you have a waste toner error code, the waste toner is apart of the drum unit in these machines so you will need to order a new drum unit for it.
easiest way to fix the problem.
Canon Tech
SOURCE: canon ir 2020 ng 853 error.
http://www.usa.canon.com/opd/controller?act=OPDDisclaimerAct&fcategoryid=2281&modelid=12301&id=57901&file=/cpr/software/imagerunner/PCL5e-c_v8.55_Win2k-Vista_INF.exe
Try this for Vista 32 bit operating system printer driver.
SOURCE: canon IR 2020 showing system Error E007 printer
my canon ir2020 is displaying system error E007
