Question about HP Office Equipment & Supplies
How do I set up HP wireless printer - HP Office Equipment & Supplies
  • HP Master
  • 3,154 Answers
6ya staff
SOURCE:
How do I connect my laptop (wireless) to my HP printer envy 5660 (wireless)?
Connect your 123.hp.com/envy5660 printer after the printer hardware setup before you print or scan from a computer through a wireless network. Install the HP printer software from a wireless network from a computer with Windows 7 or later.
STEP 1 : BEFORE INSTALLATION
  • If you want to connect the printer 123 HP Envy 5660 Setup to your wireless network, make sure you know the network name and password.
  • Connect your Windows computer to the wireless network and make sure the HP printer is compatible with the wireless
  • Obtain the network name (SSID) and network passphrase (WEP key or WPA). A broadband internet access is must be used. Make sure you have the USB cable provided along with the printer package.
  • Turn on your printer, router, and computer and make sure the computer is connected to the same wireless network you want the printer to connect to.
  • If you have connected any USB cable to the printer, disconnect it before you proceed with the software installation.
  • Follow the instructions to remove the USB installation if it was previously setup on your computer before you continue:
  • Search for the HP folder in the list of installed software programs, click the HP printer folder, and then click 123.hp.com/envy5660
  • Once the HP Printer Assistant software opens, click Utilities -> 123.hp.com/setup 5660 & Software Selection.
  • Continue to follow the prompts and click Convert a USB connected printer to wireless or Connect a new printer.
  • To complete the software installation, follow the on-screen instructions.
  • You can also run HP Print and Scan Doctor, an automated tool to connect the printer to your wireless network.
STEP 2 : CONNECT TO THE WIRELESS NETWORK
Connect your 123.hp.com/envy5660 printer to the wireless network using the built-in Wireless Setup Wizard to identify network name and entering the network password.
  • If the printer is not turned on, press the Power button to turn it on.
  • On printer's control panel, touch the Wireless icon to preview the Wireless Summary screen.
  • On the Wireless Summary screen, touch the Settings icon and then touch Wireless Settings.
  • Under the Wireless Settings menu from 123.hp.com/setup 5660, select Wireless Setup Wizard and follow the on-screen instructions to complete the setup.
STEP 3: DOWNLOAD AND INSTALL HP PRINTER SOFTWARE
Download the supportive 123.hp.com/envy5660 printer software from our website once the printer is connected to your wireless network.
  • Turn on your HP printer and eject any USB cable if connected to the printer.
  • Go to our website and navigate to the download page where you have to download the printer software manually.
  • Select your printer model when prompted and then, follow the on-screen instructions to reach the download page.
  • Next, to the full feature, click Download or click Basic Drivers.
How to solve HP Printer issues 5X Faster Answer is inside
Jul 26, 2018 | HP Office Equipment & Supplies
I have never set up or used the scan on my hp officejet 6500 wireless. I guess I need to set up to use but I am confused. I have not set up wireless either, guess I do not need.
it's up to you if you wanted to set up your wireless printer.
if you do,then set up the wireless network first.after that connect your printer via wireless.
Sep 09, 2011 | HP Officejet 6500 Wireless All-in-One...
How do I get the HP 6500 to print wirelessly?
For installing a wireless printer on Windows XP, wireless router is an essential device. Follow the recommended steps mentioned on the installation CD of the router, and set-up a wireless network. Since several computers or laptops will access the printer, it is recommended to connect the wireless printer to the main computer through the USB port. To begin the installation process on Windows XP, access the network setting in the Control Panel, and activate the file and printer sharing option in the LAN setting. This will allow the operating system to recognize the availability of a wireless printer. Now, click the Start button, go to Devices and Printers, select Add a Printer option. Click the second option- Add a network, wireless or Bluetooth printer. The computer will search for available printer and reflect it on the screen. Click Finish; and the printer is ready to begin the printing process. get more detail for Wireless Printer Setup. Hope this helps you.
Thanks
Michel Smith
Dec 13, 2010 | HP Officejet 6500 Wireless All-in-One...
HP OfficeJet 7310 wireless hookup. Can print over the wireless network, but can use scan or other functions. Worked previously but had to uninstall printer and reinstall. can't remeber wht I did do get...
If this problem arises check for updated printer drivers, compatibility between your wireless printer and Windows Vista and firewall settings. All or any of this could prevent your HP wireless printer from printing documents. Setting up wireless printers is very easy; however, sometimes certain settings can create hassles for you.
Nov 26, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Wireless hp j4680 printer will not print...offline help....
If this problem arises check for updated printer drivers, compatibility between your wireless printer and Windows Vista and firewall settings. All or any of this could prevent your HP wireless printer from printing documents. Setting up wireless printers is very easy; however, sometimes certain settings can create hassles for you. get more help......... http://h30434.www3.hp.com/t5/Printer-All-in-One-Install-and/Wireless-not-working/m-p/319330#M19085
Sep 12, 2010 | HP Office Equipment & Supplies
My HP printer will not print pages from the desktop. I ran a test report from the printer itself and it said that the Access point could not be found and that it was in fact turned off. How do I fix this?
If this problem arises check for updated printer drivers, compatibility between your wireless printer and Windows Vista and firewall settings. All or any of this could prevent your HP wireless printer from printing documents. Setting up wireless printers is very easy; however, sometimes certain settings can create hassles for you. get more help for HP Wireless Printer Problems.
Aug 10, 2010 | Cisco Photosmart C4780 Wireless AllInOne...
We have a hp c4580 wireless printer and we are having problems with getting it to work. Can you please advice what to do. Bethany
Basically, you need to configure the HP C4580 printer with the same wireless settings of your network. Thus, you need to get the following information from your wireless router:
SSID or wireless network name
Type of Wireless Security
Wireless Security key/passphrase/password
To set those settings on the printer itself, you need to temporarily connect first your printer to the computer through USB. Then run the HP Printer Setup CD. It'll ask for you to install the required software then it'll ask for you to configure the printer on a wireless network. From then on, you will need to input the wireless settings that you got from your router.
Oct 12, 2009 | HP Photosmart C4580 All-in-One InkJet...
How to connect wireless HP Photosmart C4780
here is a general steps to connect a printer to a wireless network
http://www.castleink.com/_a-wireless-printer-setup.html
Hope this helps
Thank you
Oct 02, 2009 | HP Office Equipment & Supplies
Can the HP 1610 be set up as a wireless printer?
Yes it can be set up as a wireless printer.
A generic procedure is :-
http://www.ehow.com/how_4474255_set-up-hp-wireless-printer.html
Any further help, let me know.
Thanks for using ' Fixya ' and have a nice day!!
Sep 24, 2009 | HP PSC 1610 All-In-One InkJet Printer
27 people viewed this question
Ekse
Thomas F. Schneider
