Question about Hotpoint Dryers
I have a hotpoint tcm580 dryer it makes a squealing noise and when i open the door there is a lot of steam coming from the clothes
6ya staff
SOURCE:
Amigaman
Gerald Griffin
  • 248 Answers
SOURCE: steam comes out of dryer after cycle and door is opened
Probably has a restricted vent. Go outside with dryer running and check air coming out vent. Should be a good blast...not just a breath. Clean out the vent and make sure it's not kinked. If it vinyl or foil vent, replace it! Also make sure lint screen is cleaned everytime.
Posted on Nov 18, 2007
Lumpy816
Toby Norton
  • 246 Answers
SOURCE: hotpoint washer dryer not drying clothes
Sounds like you have a ventalation problem. The clothes heat up, but without airflow, the moisture remains. First check the hose from the back of the dryer to the wall. Is it plugged, kinked, or restricted? No? Turn your dryer on and remove the hose. Do you feel pressure coming from the back of the unit? No? You need to take it apart and clean the internal airway. If you do feel pressure, reconnect it to the wall and start your dryer. Walk to the outside of the house. Do you feel a fair amount of air coming out? No? There are companies that will clean your vent in the phone book. There are also vent cleaning brushes you can buy at hardware and appliance part stores.
Posted on Jun 19, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: kenmore 90 series not drying.
remove the ventin from behind the unit you need to replace and or clean your vent !!!!!
Posted on Jan 16, 2009
jumptrout51
steve
  • 3361 Answers
SOURCE: Hotpoint Electric Dryer Model NBXR453EVOWW squealing when turned
Replace the drum support bearing at the rear of the drum.
Posted on Jun 11, 2009
Anonymous
SOURCE: PROBLEM WITH HOTPOINT WASHER DRYER - MODEL BWD
the filter cap is jammed on my hotpoint bwd 129 whats the best way to get it of and clean the filter
Posted on Mar 15, 2010
How do I access drivebelt on Hotpoint tbf770
The front of the unit might have to come off. The squealing could also be coming from the rollers .
Nov 25, 2015 | Hotpoint TVF770 Tumble Dryer
Hotpoint WDF740G Dryer not Very Hot
Most likely to be either that the capacitor is defective which starts the motor slowly at first and then picks up speed or the drive belt is worn, usually this happens when the drum has clothes in it otherwise it looks as if it is operating normally
May 22, 2014 | Hotpoint Washing Machines
Dryer was making high pitched squealing noise and now won't run
Please supply the model number so we can help further.
May 20, 2012 | Hotpoint Dryers
Can hotpoint wd61 be used as just a dryer?
you got to have the drain installed and run a cycle with water in so the the washer has water in so that it can condense the steam and drain it out. hope this helped.
Sep 01, 2009 | Washing Machines
Clothes wont dry but gets really hot
Hello, sounds like your cold water feed hose has got a kink in it. The machine needs cold water to condense the steam. Just pull out the machine and slowly slide back into place.
Oct 21, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint washer dryer not drying clothes
Jun 18, 2008 | Washing Machines
Hotpoint electric dryer
check your vent its probably clogged or kinked you need air flow to get rid of the steam
Dec 28, 2007 | Whirlpool LGR3624JQ Gas Dryer
Steam comes out of dryer after cycle and door is opened
Nov 16, 2007 | Whirlpool LGR3624JQ Gas Dryer
Hotpoint Aquarius 1200 WD62 (Tumble drying issue).
no the steam from the dryer part comes out of outlet tube the same tube were the water comes out hotpoint washer/dryers use a condensing chamber which allows the steam to cool down a pass through it as water does and through the outlet pipe
Aug 14, 2007 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint Aquarius 1100 - Grinding Noise From Drum
This sounds like the min bearings have gone, open the door and see if there is any play up and down on the drum. if so its the bearing if not it could be something that has fallen from a pocket and got stuck between the metal clothes drum and the oute drum casing. a take apart job i am afraid for both issues.
Oct 29, 2006 | Hotpoint Aquarius WD63 Front Load...
Dryers Logo
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
peter gittos
peter gittos
jimorris77
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
