Question about Maytag Microwave Ovens
Maytag Microwave Model MMV4205DB4 door switch wiring diagram
    Top Expert:
  • Maytag Master
  • 55,370 Answers
Request the diagram from Maytag.
Posted on Nov 27, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: wiring diagram Problem - Maytag MMV5207A 1100 Watts Microwave Oven
I have a micro wave national nn-v688w. now the high voltage control bc board which is gos to magnatron is useless i want to use a simple transfomer to oprate. the problem is it works for about 15-30 sec and stop the display say H87. i know i need to bild a new circut to oprate the oven so do hahe an idea.my email; raju karki05@gmail.com. thahk you
Posted on Nov 12, 2008
Anonymous
SOURCE: Cleaning inside of microwave door
THE DOOR ON MY MAYTAG MICROWAVE OVEN HAS A SCREEN OVER IT. I HAVE SOME FOOD SPATTERS THAT PENETRATED THE SCREEN AND I CAN'T CLEAN THE GLASS THAT THE SCREEN PROTECTS. HOW CAN I REMOVE THIS SCREEN TO CLEAN THE GLASS?
Posted on Nov 23, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Wiring Diagram for Microwave Door Switches
It took me a while, but I was finally able to get the FULL service manual that covers these models:
NN-S252BF
NN-S252WF
NN-S262BF
NN-S262SF
NN-S262WF
The wiring of the door interlock switches is shown on page 10.
The best place to order parts for this brand is Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Posted on Feb 05, 2009
James Chandler
  • 686 Answers
SOURCE: UMV1152BAB Maytag Microwave ... door look
REMOVE THE CABINET(COVER) AND YOU SHOULD BE ABLE TO SEE WHAT TO DO.
Posted on Apr 18, 2009
dyronwebb
Dyron Webb
  • 220 Answers
SOURCE: How do I change a bad door switch and/or door switch mount on a Maytag Model MMV5208WS1?
Take off the control panel to do this remove the grille over door should be two screws remove screw from control slide upward it should come forward take a pic of wires then remove to get panel out of the way almost forgot the spade terminals on the relay have a lock on them you have to look carefully there is a tab you need to depress to release the lock to slide off, there may be a black plastic panel in the way take out the bottom screw then you can pry out of the way you have either a bad primary or secondary switch change both not that expensive primary on top left switch 3 wires going to it secondary bottom single switch same principle to unlock terminals # 15 torx bit needed to remove the screw for door switch mount hopes this helps
Posted on Jan 29, 2015
Door switch has 2 wires.1black 1yellow. both disconnected. which goes where?
Hello Russell;
My name is Peter. I am a retired field service appliance technician.
Behind your control board you have 3 door contact switches. The top one is, "Normal" (Close operation), The middle one is, "Intermediate" (Closed operational), and the bottom switch is, "Door closed".
Usually it make no difference if the wires are the same color. You need to do a trial and error. Connect the wires to the door switch. If the microwave does not work reverse them. You will not damage the microwave.
Go into the following website, put in your model number located on a label on your microwave and you will get diagrams, and perhaps a wiring diagram. Water Filters Lawn Garden Appliance Parts
Apr 04, 2016 | Rival Rgst902 Microwave Ovens
How do you replace the door switch for the door in the microwave oven?
Take the cover off, the switches should be pretty easy to replace. In the several I've done, they just snap out, unplug, and then snap back in.
Oct 25, 2015 | In Microwave Ovens
Jan 28, 2015 | Maytag Microwave Ovens
Jes1451bj02
That is most likely a failed door switch or its mount may be loose, misaligned or broken.
It's most often caused by opening the door while it's cooking instead of hitting "Stop" first, or slamming the door.
It would either be the top or bottom switch, whichever one has the thicker wires, probably black wires.
(Sorry, but I don't have the wiring diagram on this model and the door sense switch [not a suspect] will have thinner, more colorful wires).
See these help files first:
http://031d26d.namesecurehost.com/mwd/safety.txt http://031d26d.namesecurehost.com/mwd/disassembly.txt
Then my help file on door switches:
http://031d26d.namesecurehost.com/mwd/doorsw.txt
You can find helpful exploded view diagrams and order parts by entering your full model number (JES145BJ02) here.
May 22, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
MVP V Model CMV1000ADW
sounds like you have mixed up your wiring. Refer to the schematic which is stuck to the internal casing of the machine [good luck]
Feb 16, 2010 | Maytag Appliances Over-the-Range Microwave...
Microwave Oven Model MMV5207BA/BC
E13 is usually a bad door switch or door switch mount.
The first step is to unplug it from the power outlet for one minute, then plug it back in and try it again.
If it still fails to heat, I would check the door switches and door switch mounts.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 22, 2008 | Maytag Microwave Ovens
Maytag microwave OVER the stove
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Here are some links you or a friend can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
Feb 28, 2008 | Maytag MMV5156AAS Microwave Oven
Maytag Microwave MMV1153
First of all, it's under warranty. So I would contact Maytag for a free fix.
See http://maytag.com/support/service_parts.jsp
For an out of warranty reply:
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 27, 2007 | Maytag MMV1153A Microwave Oven
Replacing door handle
The choke cover (or door gasket on your brand) will come out similar to the diagram shown below.
Then the hidden screws should be visible.
Also, you can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Oct 20, 2007 | Maytag MMV5156AAS Microwave Oven
Wiring diagram Problem - Maytag MMV5207A 1100 Watts Microwave Oven
This doesn't have the diagram hidden away somewhere inside? Check at the bottom edge of the control panel, transformer brack, or rear of the oven. Otherwise, you can find wiring diagrams of earlier models that may be close enough. Just enter your model number here: http://tinyurl.com/gv383
Sep 04, 2007 | Maytag MMV5207A Microwave Oven
Microwave Ovens Logo
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Paul Bade
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
