I have a workforce propane heater model # HD45R and I need a thermocouple for it.
    Top Expert:
  • Heating & Co... Master
  • 29,792 Answers
I found this, but it's old. Wrong model as well, but phone the number
NEED THERMOCOUPLE FOR WORKFORCE HD80A
Part # 2303105
Call 1-800-810-1463 to order
Posted on Nov 19, 2019
6ya staff
SOURCE:
protek480
Craig Butler
  • 1730 Answers
SOURCE: Need a replacement thermocouple for my DynaGlo Pro
All thremocouples have a number on them which tells what 'millivolt' output it has. Try to match that up or call a HVAC company and ask them for one with that number.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Oct 05, 2009
SOURCE: Where is the model # located on my Comfort Glow propane heater?
Usually it is a metal plate stamped to the unit.
Most common places to find it is usually located where the gas
valve and burner is located, it could be hooked to a chain.
Sometimes it is located on the side.
-Good Luck
Posted on Jan 08, 2010
dnewcombe1
Dana Newcombe
  • 1564 Answers
SOURCE: I need a thermocoupler for a model 250A propane
Thermocouples are available at most propane distributors, however, they "may" require a gasfitting license to sell it to you. You may however, be ablr to find one at Home Depot or another similar type dept store. Thanks, Dana
Posted on Jan 18, 2010
Testimonial: "Yes, but I found a distributor in IN that's seding me one for 12 bucks. "
skoehler122
SOURCE: NEED THERMOCOUPLE FOR WORKFORCE HD80A
Part # 2303105
Posted on Jan 18, 2011
Charmglow 810-7400-S Propane Grill: have a charmglow patio heater, the pilot comes on ...
I have a Charmglow Patio Heater Model SRPH02, it needed a Thermocouple and searching the net was hard to find an ariginal part, but here it is, call 1-866-814-0585 $3.95 +6.00 shipping the original part.
May 16, 2010 | Brinkmann Charmglow 810-7400-S Propane...
I need to find a thermocouple for a mr heater Model mh35fa propane. mr heater does not have them in stock
Why not take out your old thermocouple to a store that sells furnace parts for propane fired units?
The important thing is unit length and the right fastener and the rest should take care of itself right?
Good luck and be careful!
Feb 09, 2010 | Mr. Heater Thermocouple
I need a thermocoupler for a model 250A propane space heater. Where can I get it? The heater was working fine and now it only works at about 20% capacity
Jan 18, 2010 | Heating & Cooling
SPC-40 wont stay lit
Problem is either the thermocouple or the thermoelectric valve. I have one of these as well with the same problem. On mine it is not the thermocouple. I have replaced the thermocoupler and still have the problem. A thermoelectric valve is $42.25 at http://www.masterheaters.com/propane/
Im looking for a cheaper part. Any suggestions?
Gru es 1234 @yah oo.c om
Jan 12, 2010 | All-Pro Propane Garage Shop Heaters - All...
I have a rllp35a propane heater and it will ignite
either the thermocouple is bad or the pilot flame is not hitting the thermocouple .if the flame is hitting the thermocouple correctly it is most likely that it is bad and needs to be replaced
Mar 01, 2009 | Reddy Heater-30-55,000 BTU Variable
I have a propane reddi heater and I can't get it to stay on after I light it, it won't stay on. Is there something that needs to be cleaned or replaced
Generally speaking a propane heater stays lite because the pilot stays lite. The pilot flame touches a thermocouple which produces a current which keeps the main valve open. Pilot goes out or you have a bad thermocouple or the pilot is slightly clogged (reduced heat to thermocouple) or maybe the thermocouple is not touching the flame enough. Most times when a propane heater goes out the problem is somewhere in that neighborhood. Thermocouple - pilot. I have always had luck carefully taking those parts off, cleaning, and reassembling, but check the position of the thermocouple first. Looks like a small brass rod which sticks into the flame. This is a safety mechanism to prevent the flame being blown out and leaving the gas on. Good luck
Jan 16, 2009 | Heating & Cooling
Propane heater wont work
I'm not sure about that model, but I think you have to hold that button down for a minute or more to "prime" it.
I have a different model coleman propane heater that sits on the 20# tank. Mine is probably getting rusty, last time I used it I had to hold that button down for a long time.
I'm looking for a new heater now myself, as mine won't stay lit outdoors in much wind.
Dec 22, 2008 | Heating & Cooling
Reddy propane heater RLP100
Try a little longer, sometimes it takes a full minute to heat the thermocouple. Check and make sure thermocouple is in flame. If all this is ok. then your going to have to change the valve.
Nov 29, 2008 | Reddy Heater RLP100 Portable Forced Air...
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
