My Nix Advance 17" widescreen frame keeps showing the blue Nix screen and then the blue set up screen every few minutes while playing pictures. How do I stop this?
6ya staff
SOURCE:
Anonymous
SOURCE: CD Player stopped working
Probably there is dust on the lens. My CD player (different brand) did the same. I opened the case and cleaned the lens with a photo camera brush (VERY gently). Now it works fine.
If you cannot / do not want to open the device to access the lens, you may want to buy a cleaning CD.
Posted on Aug 01, 2008
Anonymous
  • 174 Answers
SOURCE: Xbox 360 plays for a few minutes and then the screen goes black with no sound or picture.
your graphics processor IC chip needs its solder joints reflowing, and the heatsink re securing.
This will solve the problem.
Regards
FixMyConsole
Posted on May 20, 2009
SD Tech
SD Tech
  • 14553 Answers
SOURCE: screen turns blue
You may have a bad blue picture tube but there is a way to deal with this first---This is a 2001 model and does not have a light engine---I did one of these with the same problem a week ago---the set has a black plastic block with six controls---three are Focus(red,green,blue) the other 3 controls are Screen controls(red, green, blue) Someone has to remove the entire piece on the front of the set below the screen(usually a plastic part) most of the time it is secured with 3 screws on either side of the set in the back; once you remove the screws the entire piece should pull out(pull from right to left(it will not fall off or come out easy--it is held in with several large plastic pegs) With it removed there is an inspection plate with 4 screws-----the screen/focus block is behind it.
You need to look very closely at the block to identify the focus versus screen controls----one row left to right will be marked Focus and the other row left to right will be marked screen------YOU need to locate the Blue Screen control(they are black like the block) With the set on(be careful) go to a video input with nothing connected---if you see a blue screen as well as the input number turn the BLUE SCREEN CONTROL SLOWLY TO THE LEFT UNTIL THE BLUE is gone.
If this cures the problem you may only be buying yourself some time----if the blue picture tube is bad sooner or later this trouble may return----I have seen sets where this was adjusted and the set worked for a year or more with no repeat of the trouble----replacing the blue tube would likely cost you 400 - 500 parts and labor.
I do this here for free so if this has helped you take a moment and give me a vote here.
SD TECH
Posted on Sep 03, 2009
Testimonial: "It seems to have made the difference. Don't know how long it will last... but, thanks!! Awesome... "
Anonymous
SOURCE: I am trying to self-clean oven. After a few
its fixed tried to clean again and no problems
Posted on Sep 09, 2009
leepania
Pania Lee
  • 1099 Answers
SOURCE: the kodak easy share digital picture frame won't show my pictures
Pls. check if there is any reaction when pressing the buttons onto the frame.
Check the batt within the remote.
Reset the frame.
If all fails:
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Oct 15, 2009
Reset advance digital frame
Page 9 of the manual suggests there's a Restore Factory Defaults option in the menu, after "motion Sensor".
https://support.nixplay.com/hc/en-us/article_attachments/115011563083/NIX_Advance_Manual_English_.pdf
Feb 24, 2018 | Advance Computers & Internet
I have a black frame around the tv picture.
Go into Settings and play with 'Aspect Ratio'. Remember though, not all shows are made in Widescreen format, and certainly nothing made older than 10 years ago.
Mar 30, 2017 | Televison & Video
How to launch antivirus app ? is one auto installed at factory
There are no antivirus apps available for digital picture frames of any type, that I am aware of ? Users manuals do not make reference to having the ability to launch or load such a tool.
(Please refer to your users manual for the Coby DP732 7" Widescreen Digital Photo Frame.) As picture frames are "play" and not "record" devices, there is no need to run virus security software on them.
May 07, 2014 | Coby DP732 7" Widescreen Digital Photo...
Hi I have Dell inspiron 1720 (17 inches) laptop with intel centrino- window vista ultimate OS Problem: after system boots up, just before windows login, it comes "Please wait" and again it...
That's an interesting problem. It sounds like it's applying new display settings, but I'm not sure why it would do so over and over again. I would suggest trying to start Windows in "Safe Mode". To do that, as the computer is booting, hold down the F8 key to get the "Advanced Boot Options" menu. Maybe this will get you to a normal login screen. If so, you should try to change your display settings to the simplest possible and then reboot. I hope this helps.
Apr 10, 2011 | Dell Inspiron 1720 17" Widescreen...
Picture Size
Keep in mind that not all programs and show are in widescreen format. When set to normal, you will get those black bars on the sides because the program is sized for the older TV's. Some TV's will have a zoom option, but that will cut off some of the top and the bottom of your picture.
Until everything goes widescreen, you are stuck in normal with those black bars or widescreen with the fat people.
I hate distortion in my TV image, so I am perfectly fine with my TV on normal.
Good luck.
Jul 14, 2010 | Philips Magnavox 42MF521D/37 Television
The picture does not fit the screen. The top and bottom of the picture go beyond the screen
you may need to adjust the aspect ratio of the picture, there is typically an "aspect" button on the remote that will adjust the picture from widescreen, super widescreen 16:9 ratio and sometimes you can zoom in. try that
Sep 20, 2009 | Samsung Televison & Video
Lg 22' monitor was widescreen now has black bars!! Cant remove ?
the grpahics from wowc burnd the sides of your monitor. your pretty much screwed if you keep playing that game
Aug 16, 2009 | LG Flatron L1710S 17" LCD Monitor
Full frame??
Hello to all. Well after a few tries I figuered it out, all you do is hold down the arrow pointing > to the right at the back and thats it full screen, I guess pressing the arrow < pointing to the left reduces the size again. Just remember to hold it down for a few seconds.Hope I was helpful, take care all.. Happy Holidays
Dec 14, 2008 | Coby DP-768 7-Inch Widescreen Digital...
Widescreen
Unfortunately, a cinema screen is even wider than a widescreen TV. Because of this (in order to keep the original aspect ratio), even with a widescreen TV you still end up with the black bars top and bottom.
Check the aspect ratio of the DVD (Should be printed on the back of the case somewhere).
Unless it says 1.85:1 or 16:9 Anamorphic, you will get the black bars. (Many films on DVD are 2.35:1 or even wider!)
Have you got any different picture modes on your TV. I've got a Toshiba and it has something called 'cinema mode' which does eliminate the bars. Unfortunately it does it by zooming in on the picture slightly, so you loose a bit off the side of the picture and the image does get a little grainier.
Hope this helps.
Matt
Feb 29, 2008 | Philips DVP3020 DVD Player
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
