SOURCE: wifi problem on iphone 2.0
I took phone to a local Apple Store. It worked fine (their network has no WEP, WPA, etc.). But it worked well. Store people told me they were using Airport N/G Access Point.
This was my first evidence that it wasn't just a poorly written WiFi module in the iPhone.
Clearly, not tested on many WiFi devices, but I had a different and newer Access Point, and Airlink101 AP431W. I hooked up the new AP, setup with no encryption, worked fine. Then tried WPA (WEP is not even an option in the newer AP), and it also worked fine.
I can access the Airlink AP431W through walls in the house and up to about 75 feet away. It's on a shelf in the living/dining room (center of activity)
PS: In the process, I checked settings, timings, etc., but nothing fixed the original AP421W problem until I swapped it for the newer AP431W.
Hope this helps
SOURCE: Connecting PSP to wifi
Change the primary DNS of your PSP to 4.2.2.1 and secondary dns to 4.2.2.2
SOURCE: Cannot connect to internet via lan but can connect
first need to know if the LAN has an IPsetup manually (static IP) if it's set static set it to obtain an IP automatic.If it's already set to obtain an IP automatic, try to reset the winsock and see if that will fix the problem, search google how to do that on DOS. if that did nottry to set the LAN card to work on 10mbps or 10 half duplex mode. if this won't work then the lan card might be bad.
SOURCE: Lan connection not working on Toshiba satellite laptop
Try setting up a new Broadband internet connection. Input all the appropriate Login info and you ought to be good to go via the LAN port. Everything else is aimed towards Wireless.
SOURCE: I have both my iMac & Samsung Smart TV
There's an adapter that monoprice.com just brought out that I purchased.
Works like a charm. It still plugs into the mini display port but it
also has a usb connector that you must plug into one of your usb ports
on your imac. This allows for the audio to travel over the hdmi with the
video. The link is below.
http://www.monoprice.com/products/product.asp?cid=104&cp_id=10428&cs_id=1042802&pid=5969&seq=1&format=2
Be aware that once you add the TV as a second screen that it extends
your desktop typically to the right of your current one. Just drag an
open window to the right and it appears on your TV. The resolution of
the TV is probably lower than the mac screen so the extension is a
different size. You can move the extension around to the
top/bottom/left/right etc.
You can see this in Preferences - displays - arrangement, After you have added your second screen.
If you don't want to extend the desktop but would rather mirror your primary display, this is where you check "mirror displays"
