Question about Whirlpool Dryers
Does the Whirlpool LER4634EQO have an end of cycle buzzer?
6ya staff
SOURCE:
Anonymous
SOURCE: Dryer end of cycle buzzer
disconnect the BUZZER wire from the Timer
Posted on Jan 29, 2009
Anonymous
  • 43 Answers
SOURCE: Whirlpool LTE5243BWO dryer buzzer doens't
unplug it or replace it.
Posted on Apr 25, 2009
Jeff Faux
  • 40 Answers
SOURCE: Can the end of the cycle the buzzer be turned off?
On the display panel under the start button is a signal indicator. If you push the button to the left of the indicator you should be able to reduce the volume and even turn it off. The button on the right of the signal indicator will bring the volume back up.
Posted on Jan 07, 2010
washerdud538
SOURCE: Cycle complete BUZZER
I too was terribly annoyed by the volume of the buzzer on the Frigidaire Gallery set that I have in my apartment. Because there is no way to turn it off with a switch I decided to look around and managed to find a technician manual that had some diagrams of where the buzzers are located.
I managed to turn both of them off and then put together a manual with pictures labeled detailing what you need to do. It takes about 5-10 minutes and requires nothing more than removing 6 screws and then pulling and taping off 2 wires but make sure you turn the power off first :)
http://www.scribd.com/doc/34420420/Buzzer-Disconnect-Frigid-a-Ire-Gallery
Hopefully this makes things easier on someone...
Posted on Jul 16, 2010
jeff britton
  • 57 Answers
SOURCE: We have a 80 series elec. dryer, today when the
Push the timer to a definate off position. Close the door. If it buzzes then more than likely you are getting power from the timer which could mean short in the timer. If you have the model # the parts places can easily find your parts.
Posted on Dec 28, 2010
The buzzer does not sound at the end of a drying cycle. I've replaced the buzzer but the problem of no buzzing still remains. How is this remedied?
About 21,300 results (0.60 seconds) Search Results
    Dryer Buzzer Replacement - Whirlpool/Kenmore Electric ...
    ? 1:11
    https://www.youtube.com/watch?v=vsLyHfJLfqk
    Jul 15, 2010 - Uploaded by RepairClinic.com
    Dryer Buzzer Replacement - Whirlpool/Kenmore Electric DryerRepair ... Additional dryer repair, troubleshooting tips, help with finding your ...
    Questions and Answers for Whirlpool 694419 Adjustable ...
    www.appliancepartspros.com/questions-for-whirlpool-adjustable-buzzer-...
    Customer Questions and Answers for Adjustable Buzzer Kit by Whirlpool ... At theend of the dryer cycle the buzzer sounds but does not time out and shut off.
    Whirlpool 694419 Adjustable Buzzer Kit ...
    www.appliancepartspros.com > ... > Washer > Whirlpool Washer Parts
    $27.64
    Adjustable buzzer kit 694419 / AP3019850 made by Whirlpool. ... At the end of thedryer cycle the buzzer sounds but does not time out and shut off.
    Whirlpool® Duet® 7.3 cu. ft. Front Load Electric Dryer with ...
    www.whirlpool.com/-.../WED80HEBW/
    Whirlpool Home Appliances
Feb 08, 2016 | Whirlpool Dryers
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
410e buzzer keeps buzzing after switch is off
sears kenmore dryer when dry cycle is done buzzer keeps ...
It can be very annoying when the buzzer to your dryer will not shut off after the ... push to start switch as soon as I close door also buzzer keeps buzzing at end of ...
My dryer end-of-cycle buzzer will only stop buzzing when I ...
I see your dryer buzzer will only go off if the door is open. ... Dryer #11079622800: End of cycle buzzer won't stop buzzing after cycle is complete. ... sears kenmore dryerwhen dry cycle is done buzzer keeps buzzing. will not turn off unless you ...
The buzzer won't stop buzzing after the load is complete. ... The buzzer won't stopbuzzing unless you open the door or turn on the timer and the dryer will start ...
Keep Your Dryer Quiet - Instructables
Dec 14, 2015 | Dryers
The selector knob on my Whirlpool LER4634JQ1 does not move, so the dryer will not turn off automatically and no "end of cycle" buzzer sounds. Do I simply replace the timer?
Your timer most likely does need to be replaced. The timer has a small motor that causes it to rotate during the cycle and those can go bad causing the timer to not advance. Unfortunately, you cannot get just that timer motor anymore. Hope this helps!
Feb 16, 2015 | Whirlpool Dryers
Whirlpool washer has begun to make a loud buzzing sound when the
This machine has an end-of-cycle buzzer built in. It may be that it just started working.
Dec 31, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Dryer
it's the button that controls the end of cycle buzzer volume /on/off should be small lock image beneath button
Apr 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Buzz when changing cycles
there isnt, or at least shouldn't be a buzzer to let you know its changing cycles, only end of cycle. if its buzzing betwwen cylces theres problem a woudl assume eith timer( if theres a selector forit try turning of end of signal chime any way
Feb 26, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Dryers Logo
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Ned Halaweh
Ned Halaweh
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
