How is the USB stick formatted? IF it is formatted NTFS or Apple, it won't be recognized, and of course the data on the stick has to be a media file format that your TV recognizes
Manual
https://www.lg.com/uk/support/support-product/lg-42LH2000
Only a USB storage device is recognizable.
- If the USB storage device is connected through a USB hub, the device is not recognizable.
- A USB storage device using an automatic recognition programme may not be recognized.
- A USB storage device which uses its own driver may not be recognized.
- The recognition speed of a USB storage device may depend on each device.
- Please do not turn off the TV or unplug the USB device when the connected USB storage device is working. When such
device is suddenly separated or unplugged, the stored files or the USB storage device may be damaged.
- Please do not connect the USB storage device which was artificially maneuvered on the PC. The device may
cause the product to malfunction or fail to be played. Never forget to use only a USB storage device which has
normal music files, image files or movie files.
- Please use only a USB storage device which was formatted as a FAT32 file system, NTFS file system provided with
the Windows operating system. In case of a storage device formatted as a different utility programme which is
not supported by Windows, it may not be recognized.
some flah drives need drivers . i think u r not using xp . the drivers can be downlaoded from the companys websit . can u ane the comapny
SOURCE: wharfedale DVD1100 PLayer does not detect USB Hard drive
I'm sure you probably have done this but i gotta ask!
When using usb there's enough power to run the usb key. When using 2.5inch hard drive the usb has enough power to run it. When using a 500gig you will need a separate powersource for it so check to make sure thats the case.
Also, a lot of these dvds will will only work with ide external harddrives and not sata external ones so make sure you use ide drives only.
good luck
smeags.
SOURCE: My mobile won't charge from USB port
in your laptop goto device manager. universal serial bus controller. go to appropriate port. Right click- properties - there you will c a power management tab. uncheck Allow the computer to turn off this device to save power. click ok.
SOURCE: my r4 sd chip is inside the usb to connect to the ports but can't
Pull up my computer and see if it shows up. If it does but does not show your files, you may be able to use a file recovery program to recover them. See end of this post.
2nd thing to try
Plug it into another computer just in case you ended up with a dinged driver on yours.
3rd
Your Cruzer may be toast but you may be able to recover your files if your SD memory you referred to has not been used since you deleted the original files. There are many computer apps out there just for doing that. Some are even free. This is just one example: http://www.pctools.com/file-recover/?ref=google_fr&gclid=CLCjzs-sl5wCFQNbxwodtkmudw
SOURCE: TV USB Input - Displays mp4 video from laptop?
this is not true..flash drive yes can carry audio/video, but unless there is some sort of media player to read the file while plug to usb...some tv monitor can open (jpeg files) photos (slide show) but not video
