Carolyn Doherty Posted on Nov 20, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I get a narrower width?
I want the letters closer together than the size 24, normal setting is giving me. I want to keep the size 24 and normal settings, I just need the letters closer together so I can print more in a smaller amount of space. Thank you.
Not Me
Level 3:
  • The Master 3,158 Answers
  • Posted on Nov 20, 2019
Not Me
The Master
Level 3:
Answers
3158
Questions
0
Helped
163756
Points
31816
What make and model of machine, or software, are you using?
Please don't make us guess
5 Related Answers
Anonymous
  • 3130 Answers
  • Posted on Jun 04, 2007
SOURCE: TV SCREEN PICTURE SMALLER
Yes you have a problem I'm afraid in the pincussion or horizontal width circuit. These circuits usually have alot of high voltage in them and is not a safe place to be experiementing around with. Most of the time, with a problem like this, there are bad capacitors or a correction transistor has failed. If the set is over a few years buy a new one. Good Luck
Anonymous
  • 234 Answers
  • Posted on Aug 28, 2008
SOURCE: Paper
If you see this message on the front panel of the HP PSC 2210 when you are receiving a fax, check that the paper size is set to match the paper size in the paper tray. (You cannot receive a fax on 4 x 6 paper or on an envelope.) Checking the paper size setting
  1. Press Setup .
  2. Press the right arrow until you see 3: Basic Fax Setup .
  3. Press Enter .
  4. Press the right arrow until you see 4: Paper Size .
  5. Press Enter .
  6. Press the right arrow until you see the paper size that matches the size of the paper in the paper tray.
  7. Press Enter .
Anonymous
  • 270 Answers
  • Posted on Jan 16, 2009
SOURCE: 2.2 ohm 2 watt resistor
connect two 1.1ohm,1watt resistors in series.
Dick O Reilly
  • 3594 Answers
  • Posted on Apr 29, 2009
SOURCE: Printing incorrect letters
Check the pitck selector slide switch it may be in PS this will give you that problem.
DickyO
Anonymous
  • 40 Answers
  • Posted on Jul 01, 2009
SOURCE: Ice maker freeze ice together
If mechanical or electronic then it has to be replaced with a modified one no way to adjust.
I have a HP laser jet M3035 MFP Series and I have this message: "Size mismatch in Tray 2" even though the tray is set to letter (ltr) and the paper is 8.5 x 11
Please, make sure the paper is well aligned and there are no gaps between side guides and the paper in the tray. If the paper is correctly positioned in the paper tray, probably your paper width sensor is not working - full with toner, displaced, disconnected or faulty. The paper passes trough the printer, but the sensor does not report the expected width for letter paper and the printer assumes it is A4 or other with less width than letter. The sensor is a plastic flag on a spring passing between optocoupler. Below the toner cartridge there is a rectangular metal paper guide with a narrow cutout on the far right. The flag's arm should be inside the cutout. Check if it's not blocked. It should be rotating freely in paper movement direction and the spring should get it back in vertical position. The optocoupler is right below the flag, but is accessible from below, after removing the High Voltage Power Supply PCB.
[email protected]
They run true to size for length. There are icons on the sole that tell you the width. A filled in icon is medium width snd an outlined foot shows narrow and wide.
What type of bike tires are they?
There are lots of different wheel sizes on bikes today (20", 24", 26", 700c, etc.), and lot of different tire widths for all those different wheel sizes. Fortunately, tires are marked with their size, so you just need to learn how to read those markings, and they are not complicated.
For the purpose of picking a replacement tube, there are just two numbers you need to know: tire diameter and tire width. These numbers are always written somewhere on the side of each tire. (Sometimes when tires get old the numbers are hard to see. Don't give up, just keep looking.) Here are some examples of what the numbers might say: 26×1.95, 700c x 25. Sometimes the there will be three numbers, something like this: 26×1-1/2×1-3/4. Don't worry about that, just remember the first number (26 in this example), and the larger of the other numbers (1-3/4 in this case). Sometimes there will be letters with the size (such as EA3 or S-6). Sometimes there will be another number or two in parentheses, for example (622) or (559-45). Don't worry about those letters and numbers. They are important for getting a replacement tire that fits, but not important for replacing the tube.
The numbers can be hard to remember. It's a good strategy to write them down somewhere to bring with you.
Dec 21, 2010 • Cycling
WHEN PRINTING - THE PRINTER SAYS TRAY 1 LOAD PLAIN PAPER, USE PLAIN EXEC INSTEAD? THE PRINTER IS LOADED WITH 8 1/2 X 11 LETTER SIZE PAPER.
You have the settinigs on the printer wrong. There are two things you need to do:
1. Open the tray and check that the paper guides are set to 8.5 x 11 (letter). There are both length and width guides in the paper tray, and EXEC size is quite a bit off from letter-it is more than 0.5 inch narrower than letter. It is also shorter than letter.
2. On the printer, use the settings button to navigate to the paper size. (The exact wording may vary; it's been a while since I worked on a 4050. It may be under print settings.) Once you find the paper size menu, configure tray 2-yes, I'm sure-to use letter size, any type. By the way, on HP lasers, tray 1 is the fold down tray on the front, tray 2 is the tray that will hold 500 sheets of paper and is the "drawer" that you load. Don't ask me why they use that numbering system.
1helpful
2answers
I want to know which knob I use to make the stitching narrower
there are generally two variable controls .. one adjusts the stitch length (distance between stitches measured in stitches per inch) ... the second is stitch width .. that adjusts how far the zigzag moves left and right .. thats usually just a number from 0 to 10 or so .. 10 would be maximum width .. 0 would be used for straight stitch ..
so you need to adjust the stitch width control to make the stitching narrower .. the controls are called different things on different brand sewing machines .. if you have the brand and model number then there may be instruction booklets available ...
2helpful
Boot size fit to board width
8 or Smaller Board Width 24cm or less (Narrow) 8.5 - 10.5 Board Width 24 - 26cm (Regular) 10.5 or Larger Board Width 26cm or More (Wide)
Top The Office Equipment & Supplies Experts
vince
littlewheel
Jean Thiebaux
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
