Question about The Office Equipment & Supplies
Hpz2100 not printing light grey or light cyan I have tried changing printheads and cartridges but when I remove and rub on a cloth the 2 missing colours do not show up from the printhead?
6ya staff
SOURCE:
IB4G2008
Patrick Michaels
  • 3587 Answers
SOURCE: HP Business Inkjet 3000
you may wish to clean the nozzles, and do a clean and calibrate
Posted on May 07, 2008
yooperbud
Weldon Dube'
  • 8637 Answers
SOURCE: I have a hp 7580
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 29, 2009
Radu Ghioltan
  • 16 Answers
SOURCE: Trouble with Designjet 110plus
Hi Paula, first of all, take out the Continuous Ink System. Second, make sure that the new printhead are good and work propretl, try to get them in another HP 110, if their work good and at your HP not working good whitout your Continuous Ink System replace the carriage assesmbly, but before that verify tge tubes of ink. Good look
Posted on Aug 18, 2009
Anonymous
SOURCE: Officejet Pro L7590 printhead message (printheads only 2m. old)!
Pull out the printhead from the computer and check the date under "warranty ends" If the warranty period did not lapse, call HP technical support and tell them about the problem. They will replace the printhead for free. I have gone through 3 black/yellow printheads and I received the replacement printheads via FedEx within 1-2 days. They will send you a pre-paid envelope to return via U.S. Postal Service via US Postal Service.
If the Warranty date on the printhead expired, then you may have to come out of pocket to replace the printhead since HP will argue that they are not obligated to replace the printhead since the manufacturer warranty lapsed.
If this is the case, check to see when you purchased the printer. If the purchase was within a year, the retailer (i.e. Best Buy) is on the hook since there is a 1 year implied warranty on products such as printers, regardless of whether the expiration date on the HP printhead expired.
Hope this helps
Posted on Sep 17, 2009
Anonymous
  • 103 Answers
SOURCE: The screen says : Printhead missing, not installed
Printhead is faulty > Needs to be replaced
call kodak aio support and get a free printhead replaced
Posted on Mar 01, 2010
I replaced ink cartridges for my Kodak EsP 7. They sold me Ink cartridges 10 B (black) and 10 C (color), however, since then my printing is blotchy. Missing words, lines, and letters throughout my...
The sources of your problems could be two-fold. One, the printhead may be getting clogged and you need to remove the printhead and soak (a couple of hours) it in warm distilled water to desolve the dried ink. Blot the printhead dry with a lint free cloth being careful not to rub the electronics. Second, the new ink cartridges (if they are not OEM) could be causing a problem. Reloaded or second party cartridges may not always match the specifications for quality required by the printer manufacturer and may accelerate "gumming of the printhead". Try a second set of ink cartridges from a different manufacturer. LDProducts.com is a good source.
Let me know if you have any other questions or problems. Thanks.
Jul 24, 2011 | Kodak ESP7 PP All-In-One Printer
Unable to align cartridges on Canon Pixma MP600 all-in-one printer. When trying to print many black streaks obscure printed area.
This sounds like a printhead problem.
The first thing I would try is to clean the printhead. Remove the cartridges and store them (stretch a piece of plastic electrical tape over the ink cartridge hole to keep the ink from drying out).
Remove the printhead and set it in warm distilled water and let the printhead sit overnight.
Remove the printhead from the water and blot the water with a clean lint free dry cloth (do not rub the printhead and contacts, or damage could occur. Set the printhead aside to air dry.
Once the printhead is dry, reinsert the printhead, remove the tape from the ink cartridges, reinsert the ink cartridges. Test print. This should clear the problem.
We can try a more aggressive cleaning solution of the distilled water doesn't clear the problem.
Let me know if you have any more questions. Thanks.
May 18, 2011 | Office Equipment & Supplies
Cyan ink will not print changed inks and still wont print epson sx515w
This sounds like the printhead is clogged with dried ink. To remedy this, you will have to remove the ink cartridges, remove the printhead. Put some warm-hot (not boiling) distilled water in a cereal dish, put the printhead in the dish with the printhead slots in the water. Let soak for a couple of hours and repeat the process. Blot (don't rub) the water off the printhead and set it aside to air dry (you can accelerate this by using a hair dryer on the warm setting). One the printhead is dry, reinsert it and the ink cartridges. This should clear the clogged nozzles.
Let me know if you have any other questions. Thanks.
Jan 18, 2011 | Epson Office Equipment & Supplies
Problem printing cyan
It's going to cost you ink but your may get it working again.
- Remove all ink cartridges - Remove the printhead itself - Carefully (avoid splashes!) hold the printhead under running warm water until the water runs fairly clear - In a bowl large enough for the printhead, put about 1-1 1/2" (25-40mm) of household plain or 'sudsy' ammonia - Set the printhead in the ammonia and ignore overnight - Repeat the water cleaning - Shake out as much of the water and you can, then allow it to dry for at least 24 hours - Reinstall printhead in printer I have better results starting with fresh ink cartridges but have had to use a removed one now and then.
This is one of the printers that does not object to frequent use but will clog if allowed to sit too long between operations. If your memory is better than mine, do one of the print tests every couple of days.
Apr 03, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
How do i replace the printhead
The Print head is sitting in a cradle. So do not confuse the cradle with actual print head. The cradle is the one that slides left and right on the metallic rod. Do NOT try to remove the cradle.
Make sure to use genuine Canon ink cartidges.
1) Unplug the power to the printer. Remove the USB printer cable.
2) Lift open the top cover by depressing the round button on the right side of the printer; exposing the printer ink cartridges.
3)Lift the grey lever on top of the cartridges. This dis-engages the printhead electrical connections. Remove all the 4 ink cartridges from the printhead. From the cradle hold the printhead from the top and lift the printhead by tilting it toward you. Make sure not to touch the electrical contacts in the back printhead.
4) Take a small plastic bowl and fill it with 1/4 inch or less with Rubbing Alcohol(70% Isopropyl Alcohol). Dip the bottom of the printhead in the alcohol. Soak printhead in the alcohol and shake it lightly so the dried ink clogging the printhead can come loose. Us paper towels to soak excess alcohol from the bottom of the printhead. Make sure not to damage the printheads.
5) Pour some alcohol from the top of the each inlet of the ink cartridge seat and again soak up any excess alcohol with paper towel. Let the print head dry up little.
6) Put the printhead back in the cradle and insert back the ink cartridges in their right seat. Lower the grey lever back into its position so the electrical contacts are made on the printhead.
7) Plug the power and USB port.
8) Print a picture or diagram with color in draft mode. You might have to do this couple of times, so that the inks starts flowing from the ink cartridge through the print head. Then print the same in high quality. If the heads are unclogged your printer should work as new.
Just one bit of advice: you may wonder if you've got the position right because the grey lever may not seem to be able to engage - it will, but needs a fairly strong push to click into position again.
Oct 11, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Despite deep cleaning still poor flow on cyan, resulting in poor colour mix..can i use a head cleaner?
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
Aug 19, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Changed printer cartridge, color is not right on printed material
Remove the cartridge and blot the printhead on a damp tissue. A working tri-color cartridge would have a stripe of cyan, yellow and magenta on the tissue.
If one or more of these are missing you will not get proper colors from the printer. If your printer has a "prime" function this may recover a missing color. If not you will probably need to get a replacement.
Please provide details of the printer model for further suggestions.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Jun 03, 2008 | Lexmark Office Equipment & Supplies
HP Officejet 7130 xi all in one say Bad Print Head
printer flashes lightes and instructs to turn off and on. When ask to print
Apr 06, 2008 | HP Officejet 7130 All-In-One InkJet...
Printing light colors does not work
You RINSED the printhead???
I wouldn't do that again.
Try taking a damp cloth and dabbing it against the printhead nozzels until you get lines forming on the rage from the ink (the nozzels you're having trouble with specifically).
Erice
Oct 29, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
29 people viewed this question
Top The Office Equipment & Supplies Experts
Thomas F. Schneider
Keith Love
James Cagle
James Cagle
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
