It is cracked I barley changed the password and forgot what it was
Hi Anonymous-
I found this link.
https://guidebelajar.blogspot.com/2017/05/guide-hard-reset-lg-k20-plus-remove-forgotten-password.html
Hope this helps.
SOURCE: Forgot Password for LG Dare
It should be the last four digits of your number.
Unless you changed the password!
SOURCE: Unlock my Sprint LG Lotus Phone if i forgot my lock password
As long as you know your security code you can retreive your lock code. On the Lotus dial ##3282# scroll down to Advanced, choose View, then scroll down to option 5 which should be the Lock Code and select it. You will need to enter your security code here which typically is 6 zeros.
SOURCE: i got a samsung corby plus phone and i change my password. unluck
You need to call your service carrier.
SOURCE: crack bios password on my lg x110 - forgot bios password - can not get factory reset - help please
A password is required for access to the BIOS and I do not know the password. I have had this problem for quite some time now but luckily I've managed to get access to the BIOS now. I used lots of different programs to crack the password but I failed in vain. I removed the little battery that sat on the motherboard but nothing happened, I ran Hirens bootcd 15.1 and it did not help either. Eventually I got hold of a new system BIOS for my LG X110 and then flashed my BIOS. No password is needed now :) Download LG Notebook (X110/XD110) System BIOS here -> http://download.notebook-driver.com/driver/LG/X110/BIOS_Setup_X110.zip and run the program. That should solve your problem, because it did for me :)
Testimonial: "how to flahing bios my lg x 110 laptop.i dont pls help me how to flashid bios lg x 110.thank you"
SOURCE: i forgot my password to my lg versa how do i unlock it
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
