Televison & Video Logo
Jennifer Hill Posted on Nov 20, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Sceptre tv DVD combo and lost the remote how can I reset parental controls
barn2897
Level 2:
Habit-Forming:
New Friend:
  • Expert 153 Answers
  • Posted on Nov 20, 2019
barn2897
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
153
Questions
0
Helped
67367
Points
428
Hi Jennifer-
I found this link
https://www.manualslib.com/manual/515995/Sceptre-E195bd-Shd.html?page=30#manual
On page 23 of the manual, it shows how to use the side panel buttons to get to the MENU. from there, you can get to the parental control feature.
On page 30 of the manual, it shows how to set up the parental control feature.
Hopefully, from here you can reset your parental controls without the remote.
Hope this helps.
5 Related Answers
Anonymous
  • Posted on Nov 01, 2007
SOURCE: Parental Controls
I am having the same problem. I have a Mintek 2110, but lost the remote control. I found this code on the Time Warner Cable site. 2096. I'm going to try and plug it into my universal remote this evening. If that works, the default passcode should be 88888. That's what I remember my code being years ago.
Anonymous
  • 185 Answers
  • Posted on Mar 08, 2008
SOURCE: Need Remote Control Code
All these codes are used by Teac
Hopefully one will work for you
0037
0512
0455
0264
0009
0412
0349
0041
0000
0278
0037
0081
0307
0609
0110
0717
Anonymous
  • 291 Answers
  • Posted on Apr 27, 2008
SOURCE: universal tv remote control codes for a hikona tv/dvd combo
you have to set the code for TV alone, then code for DVD
Anonymous
  • 56 Answers
  • Posted on Jan 14, 2009
SOURCE: toshiba 13' tv dvd combo, Fios remote control need code
Greetings!
Here are the codes: take a deep breath:
0181, 1283, 0183, 1292, 0087, 0677, 0859, 0872, 1183, 1383, 1683, 1731
You may find that these don't work. Often, with combination pieces like yours, you will find you are lucky if you can get a universal remote to turn it on and change the volume and little more. The fact that Toshiba did not build this peice can compound the problem. My suggestion, if you can't get the universal to program up, is to use the original remote for the set. If you do not have the original remote it is available from www.encompassparts.com for around $15.00 plus shipping. The original part number for the Toshiba remote is 72796929.
Rob
Anonymous
  • Posted on May 29, 2009
SOURCE: trutech t2000-d remote control codes
I have a trutech 20" lcd tv/dvd from target and the remote code for the dish network remote that worked for me was from the Daewoo list "505"
I am trying to input a parental code on a Sceptre tv but I have no remote control how do I enter the code without a remote
You can't. All televisions need a remote control. How can you have a television without a remote, they all come with one! They are readily available online, Amazon, eBay or from Walmart
https://www.google.com/search?q=sceptre+tv+replacement+remote+control
3answers
Parental controls
try giving the reset ...........
1helpful
4answers
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
2answers
Lost remote for akai tv/vcr/dvd set
I think you should look over the Internet to buy one from places like Ebay for your brand of TV.
Wont Play DVD
any remote should work but i suggest a name brand like sony logitech or phillips because you dont want to have to replace this for a while and namebrands offer more functions than generics.
As for the dvd not playing dvds it appears the parental lock may be enabled preventing movies from starting after previews .
after you obtain the new remote and have programmed it scroll through the tvs set up menu to see if parental lock function is on if not drop me a line so we can narrow things down also try to push enter button on new remote if the play button doesnt start movie.
DVD parental lock
I have a GE 13TVR62 (with a problem listed here). I've learned that the Parental Lock Settings are changed by using the Remote Control. Usually the actual Settings are changed by pressing the Up or Down or Left or Right Arrows to make the Change; while the Parental Lock is Highlighted on the Menu.
1helpful
Resetting the parental control password?
try master pass 3308 Childlock The CHlLDLOCK function prevents chiIdren from watching TV. HoId down the F button and then press the MUTE button until the symboI ? ? appears on the screen, and the TV enters the CHlLDLOCK mode. Except for the symboI? ?, the screen becomes blue back and mutes when you press the buton to turn the TV off, then turn the TV on after setting the CHILDLOCK function. To unlock the TV, hoId down the F button and then press the MUTE button again. Note: The CHlLDLOCK can be set or cancelIed only by the remote controI. After setting CHlLDLOCK, secure the remote control in a safe place
Top Sceptre Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
