The owner's guide provided with the product is wrong and does not provide proper information on linking devices
Your Sylvania speaker was made by Curtis - try contacting them
https://www.curtisint.com/product-support/
SOURCE: Need help with re-setting time, date etc - haven't got a user guide or manual
If your telephone system is an NEC IPK, Pro II, or Elite, you should be able to go to extension 100 or 101 and dial Feature 9 and enter the new time. To switch between am and pm, press the Recall key after you enter the new time. If your extension numbers do not include 100 or 101, this should work from the 2 lowest extension numbers. The type telephone you have can be used on other NEC systems, and these instructions will only work on the ones I listed above.
SOURCE: Need user guide or manual to set time, etc
NEC Electra Telephone System Changing the time on a Electra Elite & Professional system must be done from the "main" or primary phone. It is usually extension # 100. Press "FEATURE" Dial "9#" Enter hour and minute Press "RECALL" to change AM/PM setting Press "HOLD" to change the calendar setting Press "RECALL" to change the day of week Dial "#" to move the cursor to day of month field Enter day of month Press "RECALL" to select month Dial "#"to move the cursor to year field Enter last 2 digits of year Press "FEATURE"
SOURCE: unable to pair bluetooth headset to cell phone
After you have found the device trying enter 0000 as your password and you should now be connected.
SOURCE: CMT-BX5BT SONY spkrs aren't pulling in music (via BT) from laptop
I had the same problem. Here's the fix:
Control panel- Hardware & Sounds- Manage Audio Devices (under Sound)- Select Bluetooth Stereo Audio as default (right click- default) and Enjoy!
