Check the following .
You downloaded the driver here? :
http://us.acer.com/ac/en/US/content/drivers
You may have to restart your computer.
If that doesn't work, you may have to update the BIOS on your computer....according to acer...
http://us.acer.com/ac/en/US/content/windows10-eligible-models
Attach an external mouse. Most Laptops will allow you to connect and external USB mouse.
SOURCE: gateway solo 9300
Sounds like the cable is not securely connected to the motherboard.
I would doubt the OS is responsible for this problem.
Nice little machine, the service manual is available for download for free. Might give a shot at refastening the cable.
If you're not that enthusiastic about taking a laptop apart, possibly an external mouse?
Put XP back on. If you have enough memory, it runs just fine.
Good luck
SOURCE: Acer Aspire 5532
look there is a problem with the touchbad diver and this is common but the keyboard must work it s nothing with the keyboard so please check if all the key board works under another operating system and then if it wrks try to reinstall windows 7 again and it must work conntact me if you still have a keyboard problem you must try to plug a usp keyboard and see if it work so you have a problem with your board again if it worked you have a problem with your keyboard if it didn't work then try install windows 7 agin
SOURCE: my labtop 5630z my touchpad not work i tray to
Dear friend your touchpad is locked & that's why your not able you use it. For unlocking use FN+F7 after running your operating system.
Thanks & I am sure your problem is solved. Waiting for your feedback.
SOURCE: my touchpad stop work.pls help me!I have an acer
i found the issue you might have a bug where after it installs the FN Key actually locks out your touchpad. I just figured this out after installing all known drivers to man on my laptop. Lol, go figure a vista recovery bug created this error. Hope this helps you out (Hold in FN Key + The Mouse disable/enable key to possibly fix the touchpad)
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/ronald_0625deae585c3a07
SOURCE: My touchpad stopped working on my acer 5532. I
> you just have to reinstall driver for your touchpad but if after doing that and still not working then touchpad might be busted
> sometimes a certain software might be causing the touchpad to not work and restoring computer to factory default might resolve the issue but this will cause your files so do a back-up first
> to get the driver for your touchpad please refer to your manufacturer or to the website of acer
