Vacuums Logo
Jessica Lisk Posted on Nov 21, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Model fh51001. Why doesn't handle stay locked in the upright position?
Thatvacguy.com
Level 3:
  • Hoover Master 1,619 Answers
  • Posted on Sep 24, 2021
Thatvacguy.com
Hoover Master
Level 3:
Answers
1619
Questions
0
Helped
604389
Points
3345
The pedal or part of the body where the pedal catches at are probably broken or worn
5 Related Answers
debbily
Debra V
  • 101 Answers
  • Posted on Oct 11, 2007
SOURCE: Dirt Devil vacuum Release pedal not working
take off the bottom like you are replacing the belt. You will find a little metal clip that controls the upright lock.  It may be lose or broken.
Anonymous
  • 1673 Answers
  • Posted on Mar 18, 2008
SOURCE: Foot Pedal was knocked out of alignment
You will have to take the top loose so you can put the handle release in its place. It probably isn't in the right place, either that or a piece of it broke off and it needs to be replaced.
Anonymous
  • 83 Answers
  • Posted on Jul 30, 2009
SOURCE: handle wont go to upright position
The red pedal has slipped out of position. On both ends of the red pedal you'll see metal rods (the axel of the pedal). On one side you'll see the metal rod sits into a long groove, on the other side you'll see the metal rod sits into a round hole. They both have to be in the long grooves so you have to reposition the rod that's into the round hole by pulling it out and sliding it back into the long groove above the round hole. You'll now be able to bring the handle up and lock the machine back into the upright position.
Anonymous
  • Posted on Feb 03, 2010
SOURCE: My Hoover Z 400 collapsible vacuum won't lock in
this just happened to me. i took the vacuum completely apart and found that there is a locking plastic "tooth". this had snapped off but still it the track. the damage was bad but i was able to wash of all the lube off it and used a 2 part epoxy glue to put the tooth back into place. it works ok now. Not like new but it will hold. this was sorta easy but i enjoy fixing things. If your not handy i wouldnt recommend you try it. i am in the process to making an aluminum version of the tooth so it wont break again.
Anonymous
  • Posted on Mar 09, 2010
SOURCE: dyson 28 handle is stuck in the locked and upright
how do you remove the air duct (plastic sliding piece) that is making the vacuum stay in locked upright p[position?
1helpful
Bissell 3576 height adjustor broken
Hi Chris! Lock the vacuum in the upright position, set the height adjustment to the desired setting, then recline the handle for the change to be made.
If you continue having difficulty, you may want to have one of our Authorized Service Centers inspect your vacuum.
Here's a quick link to help you locate one in your area: http://www.bissell.com/service-centers/?cid=ccsocial
How do I get the vacuum to go back to its upright position after vacuuming
The upright stabiliser is designed to lower and lock into place automatically when you raise the handle. If it doesn't seem to be doing this as usual, please call our Helpline on 0800 298 0298 (UK), or 1-866-693-9766 (US) so we can provide further assistance to resolve this.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Handle is locked in upright position. How can I release to use vacuum
I'm sorry to hear you're having difficulties with your DC28. The cleaner should recline easily into the vacuuming position when one foot is placed on the cleaner head, and the handle is lowered. If it's not doing this, it might be worth using a little more force than usual, in case the upright lock mechanism has jammed. If this doesn't help, or if you're reluctant to try this, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and provide further assistance. You can call us free on 1866MYDYSON - or if you email your details to [email protected], someone will be in contact as soon as possible.
Kind regards,
Jack
Handle will not go back. It is locked in the upright position.
I'm sorry to hear you're having difficulties with your DC28. The cleaner should recline easily into the vacuuming position when one foot is placed on the cleaner head, and the handle is lowered. If it's not doing this, it might be worth using a little more force than usual, in case the upright lock mechanism has jammed. If this doesn't help, or if you're reluctant to try this, it's probably best if you get in touch with us directly, so we can help you resolve the issue as quickly as possible. You can call us free on 1866MYDYSON - or if you email your details to [email protected], someone will be in contact as soon as possible.
Kind regards,
Jack
1helpful
2answers
My Dyson DC-18 won't click and stay in the upright position. Ideas?
Hi its Darran at Dyson.
It is difficult to confirm what may be causing this, however its worth ensuring that when you lock the machine back up into the upright position position, that you push the handle slightly forward when you try to do this to help the pedal engage.
If this is not working, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
5helpful
X1.1 model has plenty of suction through the nozzle, but doesn't 'pull' across the floor anymore or pickup dirt when using upright
Assuming that the automatic height adjuster is working properly, most likely your Sebo needs a new brush roll because the bristles on the old one are worn to the limit. To test the height adjuster, put the machine in the normal operating position (with the handle not upright) then switch on - the green "down" light may come on briefly (or may stay on if the brush is worn). Then, leaving the machine switched on, move the handle to the locked upright position - the green "up" light should come on, and you may be able to see the whole machine tilt backwards slightly as it lifts the brush off the floor. If that happens, the adjuster is working properly and you definitely need a new brush roll.
I hope this helps. If you need more guidance, just post a reply here and I'll get back to you soon. Please remember to rate this answer as I do value feedback. Good luck!
8helpful
2answers
Dyson 28 handle is stuck in the locked and upright position. Vac runs fine, just can't get the handle to release to run the vac
On the lower right side of the body of this model is a air duct piece that can get stuck and won't allow you to use the release. Take out that piece and put it back on again to see if that will unlock it.
Upright lock broken
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=559827
Generic problem for all Vacuums
Upright lock broken
Posted by diamond8990 on Apr 30, 2008
Upright lock broken
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Not knowing the brand name and the model # it sounds to me that you have a broken handle release if that is what you are referring to as “Upright Lock Broken” – the handle release lever keeps the hand staying up and in the upright position. So include @ least the brand name and or the model # and I can try to further assist you. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Don – The Vac Man
Go Ahead. Use Us.
Apr 30, 2008 • Vacuums
Top Hoover Vacuums Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
