Question about RCA Televison & Video
Unlock rca tv
Model le32b30, I tried all the responses on the computer. Ican't unlock the tv without the rmote. I can't reprogram the remote without unocking the tv. AAAAAAAAAhhhhhhh
    Top Expert:
  • RCA Master
  • 30,351 Answers
You can't do anything without a remote. How can you not have a remote for it! Just buy a facsimile remote, the same as the old one.
https://www.google.com/search?client=piriform&ei=J-HWXfG-Ksm0ggfRhqvgDQ&q=model+le32b30+replacement+remote+control
Posted on Nov 21, 2019
Testimonial: "I can't seem to get my message across. The tv is locked out, I can't program any of the remotes without unlockin the tv"
  • Andrew Taylor
    Andrew Taylor Nov 21, 2019
    No, you aren't understanding. You need a new remote for that television. I do NOT mean a Universal Remote, no one buys those any more! With a new remote, you can access all the functions just like you can with the remote that came with the television. It is called a Facsimile Remote, an exact copy of the factory remote. A company like thishttps://www.replacementremotes.com/RCA/R...
    In fact, here you go. You listed your model number wrong. Here is your remote for less than 10 bucks!
    https://www.amazon.com/Replaced-LED50B45...
    No programming or paring is needed.Just install new batteries and it is ready for use.
    USA Amazon Warehouse Shipping, Fast Delivery!
    Power Supply: 2X 1.5V AAA Alkaline Battery. Batteries and manual are not included.
    Please feel free to contact us if you have any query, thanks!
  • Andrew Taylor
    manual
    https://www.manualslib.com/manual/683154...
6ya staff
SOURCE:
Anonymous
  • 207 Answers
SOURCE: universal remote
Codes for Samsung (one of them should work on your RCA remote)
006,011,014,015,019,027,036,037,077
Programming Your Universal Remote.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Posted on Apr 10, 2008
Anonymous
SOURCE: unlock rca truflat tv with no remote
Buy a universal remote and program it for the TV. That's the only thing that will work.
Posted on May 05, 2008
Anonymous
  • 6 Answers
SOURCE: RCA remote help
I GOT THIS FROM THE RCA WEBSITE...IT WORKED FOR ME...THE CRUCIAL STEP IS TO KEEP PRESSING THE REVERSE BUTTON!!! MY REMOTE WAS THE RCA RCR312W
  1. TURN ON THE COMPONENT (THE TV, DVD, ETC)
  2. HOLD THE TV (OR DVD) BUTTON AND THE ON/OFF BUTTON AT THE SAME TIME.  IT WILL STAY LIT.
  3. PRESS THE PLAY BUTTON EVERY FIVE SECONDS until the component turns off.
  4. Each time the Play button is pressed, the illuminated ON-OFF button blinks ten times and a block of 10 codes is sent to your component. This process continues until all the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited.
  5. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again.
  6. If the component does not respond, continue to press the REVERSE button EVERY TWO SECONDS until the component turns on again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks.
  7. If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again.
  8. To save the new code, press and release the STOP button.
  9. The illuminated ON-OFF button turns off. You must press the STOP button to save the code.
Posted on Jul 08, 2008
Anonymous
SOURCE: how do I reprogram my remote
i need find manual
Posted on Dec 30, 2008
Anonymous
  • 814 Answers
SOURCE: proscan universal remote
Found these codes on the website for PROSCAN. www.oncorpus.com, for you model television.I hope this help you with your problem. UNIVERSAL REMOTE CONTROL CODE LIST
For Universal Remote Control brands listed below, please use accompanying Proscan codes
and refer to your Universal Remote Control User Manual for basic instruction for changing TV code to
operate Proscan model.
Proscan codes for Sony TV=8003,8012
Proscan codes for Philips TV=1005,1006,1007,1035,1064,1216
Proscan codes for other universal remotes=272,132,134,116,040,016,024,056,019,262
Posted on May 21, 2009
How to unlock without remote
RCA TruFlat 27F520T 27" TV Unlock without remote ... - Fixya
www.fixya.com > ... > RCA > RCA TruFlat 27F520T 27" TV
Question about Apex Digital Standard (CRT) Televisions. 1 Answer ... unlock key lg lcd tv without remote how do I unlock an lg tv without using the remote?
unlock child lock tv without remote Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your unlock child lock tv without remote question. Get free help, tips ... How to off child lock off in my panasonic tv without a remote? ... tv without aremote? iv ... Are you a Standard (CRT) Televisions Expert? Answer questions ...
How to Unlock a TV Without a Remote ' eHow
www.ehow.com > Tech
How to Unlock a TV Without a Remote. In life, simple yet unexpected events take place, such as the loss or an accidental breakage of the television remote.
How to unlock without remote control model - Standard (CRT)
Jan 20, 2016 | Televison & Video
I have an RCA tv model # f27159wn, we had a universal remote to turn it on because the power button is missing. Our son lost the remote, when we found the remote it doesnt turn the tv on now. How do I...
RCA tv codes from the original RCA 3-in-1 universal remote.000,181,100,233,203,212,098,005,003 004,006.One of these codes program for the RCA universal remote will work.Sorry but to find the tv wright codes for the tv to work.The tv must be power on and working to find the tv wright codes to program in to turn the tv off to get the tv wright codes.Try website like Rmotes.com to buy the tv original remote,will not require tv on to used the tv original remote.
May 03, 2011 | RCA 4-in-1 Universal Remote Control
Accidently locked the fpa using menu button on the tv. Can't find the remote.
Hello
Without its original remote control it is difficult to unlock your RCA tv. If you haven't one, try to get it from any one amoung your friends who owns your model for just to unlock your TV. If you can do this, inform me by Fixya. I'll send you the proceedings to unlock your RCA TV. ok.
Mar 04, 2011 | RCA 27V520T 27" TV
How can I turn off CC without remote on my Phillips Model 24PT6341/37 Flat Screen TV
Used the tv front bazel frame manual control buttons,get into the tv menu look for Colse Captioning funnctions turn off all cc to off.Very difficult to turn Close Captioning off,without a remote.Try website like Rmotes.com to buy an original remote.
Jan 08, 2011 | Philips 24PT6341 24" TV
I have and RCA RCR311ST Universal Rmote Contro which I can not seem to find the Cole Selector button to program my Orion TV any ideas?
I can help you reprogram your RCA RCR311ST for all your Orion TV. The folks at RCA did away with a code search button for this model and you must press a combination of buttons to setup programming more.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Entering the codes you have looked up for your Orion TV on this remote's device code list.
I hope that helps.
Jan 20, 2010 | RCA RCR311S Remote Control
Lost remote control functions
Hi, The remote lost the code and needs reprogrammed, there are 8 code choices for a sanyo tv. Manually turn on the tv. On the remote, press the code search key till it lights, press the tv key, it will blink then stay lit. Aim the remote at the tv, keep it pointed at the tv and press the on/off key ONCE. When the tv turns off press enter. If you wait more than 3 seconds it will scan to the next code. So if you try it the first time and not all of the functions work correctly is when you would let it scan to the next one. Good Luck! Please rate my response.
Feb 08, 2009 | RCA RCR412B Remote Control
I programmed an rca universal remote by:
TURN ONTHE TV
HOLDING DOWN THE TV ANDTHEON/OFF BUTTON ATTHE SAME TIME.UNTILTHEON/OFF BUTTON STAYED ILLUMINATED.
PRESS THE PLAYBUTTON IT WILL BLINK,IF TV DOES NOT GO OFF PRESS PLAY EVERY 5 SECONDS UNTIL TV GOES OFF.
ONCE TV TURNS OFF HIT THE REVERSE BUTTON THE TV WILL COME BACK ON.
HIT THE STOP BUTTON TO SAVE THE CODE.
REPEAT THIS BUT HOLD THE OTHER DESIRED DEVICE INSTEAD OF THE TV.
HOPE IT WORKS
Igotthisinfo from google....then typed in rca universal remote...there was a sight for programming remote.
Jul 26, 2008 | Sanyo DS24425 24" TV
Need code to reprogram to an RCA tv
What is the name, model # of the universal r/c, and the model of RCA t.v.?
Please, do not be offended when I correct you.You cannot "reprogram the RCA t.v." because only the r/c[remote control] can be reprogramed.
Apr 12, 2008 | RCA Universal Remote Control
TV won't respond to ANY remote control
unplug the tv, wait 1 minute so it resets to factory settings then reprogram the remote
Aug 21, 2007 | RCA F36450 36" TV
Televison & Video Logo
29 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
