Are you sure the power supply is working ? Have you looked in the manual concerning the remote control ?
Many times frames not displaying pictures are often associated with a problem with the files stored on the memory card. confirm any memory cards you're using are working properly - you would possibly got to insert the memory card during a camera to check it. If the memory card has photo images stored on it from multiple cameras, it could cause the digital photo frame to be unable to read the cardboard . Finally, try resetting the frame.
SOURCE: Need PANDIGITAL PanDigital 8.0" Digital
I don't like pasting information, but this is the link to the manual.
http://akamaipix.crutchfield.com/Manuals/692/692PAN902B.PDF
Don't forget to rate my solution, and thanks for coming to FixYa.
Rob
SOURCE: my pandigital 1.8 inch digital photo frame won't turn on
You have to leave it in your US-B overnight to charge.
There is nothing in the instructions to explain this.
SOURCE: my pandigital frame no longer
If you have an all grey screen than the frame is dead --- which menas throw it away. Check voltage on the power supply. Make sure voltage matches the output on the power supply. Also try connecting it tto the computer and formatting the internal memory.
SOURCE: Trying to move photos from Apple Mac to Pandigital frame
Its easiest to transfer the pictures to a usb drive or sd card and insert them into frame and copy them to the internal hard drive. Using Mac OS X Snow Leopard v10.6.2
SOURCE: My pandigital photo frame doesn't work at all.
This frame cannot initialize; this is an internal memory issue. Connect the frame to your computer with the USB cable and to the AC
outlet. Now turn it on. Under Computer or My Computer, look for a
Pandigital (X:) drive.
If you see that drive, right click on it
and select Format.
Choose FAT or FAT32 as the file system, check
Quick Format, then Start.
Once it finishes, unhook the frame and
restart it.
If you do not see that drive, your frame is toast.
Grab your receipt and return to the store or call the company.
