My sprint galaxy s7 edge was hacked, wiped when i tried to hard reset it then started boot loop with no destination file to be able to recover. what do i do?
If you forget the pattern lock then you have to hard reset your samsung galaxy s7 edgi. This rese will wipe all your data in the phone & remove it`s pattern lock.To do this please follow the steps below:
Ensure the device is powered off.
Press and hold the Volume Up and Home buttons.
While continuing to hold volume up and home, press and hold the Power button until RECOVERY BOOTING appears in the upper-left then release all buttons.
From the Android Recovery screen, select Wipe data/factory reset.
Utilize the volume buttons to cycle through the available options and the power button to select.
Select Yes.
Allow several seconds for the factory data reset to complete.
Select Reboot system now.
Allow several minutes for the reboot process to complete.
If applicable, set up your device.
24x7unlockcodes.com is the right place to unlock your Samsung Galaxy S7 Edge. You may need this when you are switching your sim card for change your network or visiting abroad. You can get your unlocked permanently by our hassle-free procedure in a competitive price online at your door step!!! Just order us & relax at your home, we e-mailed you once it done.
Use of unlock code for Samsung Galaxy S7 Edge network unlocking is totally legal. We insured you that our service will not change any feature or behavior of your Samsung Galaxy S7 Edge. The data in your Samsung Galaxy S7 Edge will also remain protected. Under circumstances like, If the code will not successfully derived by us or will not work on your Device, we guarantee our customer fully refund of their money.
Please note that hard resetting erases all the data on your device. Text messages, photos, videos, settings, everything will be removed in the process. So, don't forget to create a backup of your Samsung Galaxy S7 or S7 edge before proceeding.
Also make sure to juice up your smartphone to at least 60% or keep it plugged in during the process. You don't want to have your device turned off when you hard reset Galaxy S7 or S7 edge, or it will create further issues.
Factory reset Galaxy S7 or S7 edge the easy way
Open the Settings app.
Choose Backup & Restore > Factory Data Reset.
Now select Reset Device > Erase Everything.
Confirm the warnings and wait for the process to finish.
Once done, reboot your phone.
Hard reset Galaxy S7 or S7 edge using recovery mode
Power off your device.
Wait for a few seconds while your phone is shutting down.
1. Turn off Samsung Dart. Press and hold Volume up key + POWER on the
phone. Reset
2. When the Android System Recovery screen appears, release the keys.
3. Using the volume keys, scroll down to Wipe Data / Factory Reset.
4. Press the Power key to confirm.
5. With Volume select Yes -- delete all user. Press the Power key to
confirm.
After master reset select Reboot System Now. Press the Power key to confirm.
6. Your T-mobile Samsung Dart phone reseted to the factory default state.
(This should work but if not, try both volume + power)
Samsung T-mobile Dart reset
A Samsung T499 master reset restores the original factory settings and
may erase all downloaded content, including ringtones, images, programs,
and contacts stored in the internal memory. It does not erase data
stored on the SIM card or memory card (if available).
To perform a hard reset, follow these steps.
Samsung Dart T499 Factory Data Reset
From this menu you can reset your phone and sound settings to the
factory default settings.
1. Press Samsung Dart T499 reset - Samsung Dart T499 reset and then tap
Samsung Dart T499 reset settings key (Settings) - Privacy.
2. Tap Factory data reset. This action erases all data from your phone
except current system
software and bundled applications, or SD card files such as music or photos.
3. Tap Reset phone - Erase everything.
Samsung Dart Password code try 1234
or
Use this method to hard reset your Samsung Dart Android phone: Enter
*2767*3855#. Warning! All your data including contacts, messages etc.
will be lost! Copy all your necessary data/Contacts/Messages etc. to SIM
or make backup to your PC before full reset! Take out SIM card before
full reset.
Not sure what Al is? But here's the info to unlock that make and model of phone, 2 ways to unlock the phone-
Warning: Do not enter any wrong unlock unlock codes on your Samsung SGH-E350 mobile phones. If you enter over a certain amount of wrong unlock codes on your mobile phone, your phone may get hard locked and sometimes become unusable.
Method 1:
1 - Switch ON your Samsung SGH-E350 with a NOT ACCEPTED SIM Card.
2 - Samsung SGH-E350 will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung SGH-E350 shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung SGH-E350.
3 - Compose : #0111*CODE#.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung SGH-E350 is locked to.
CODE: Its the unique Unlock Code for your Samsung SGH-E350.
If method 2 does not work, you can try method 2 again but this time without any SIM card on your Samsung SGH-E350.
*** and this would be a valid unlock code-
*2767*3855#
IT RESETS THE MEMORY.MIGHT WORK WITH OTHER SAMSUNG MODELS.WILL NOT HARM YOUR PHONE.
~good luck~
Check with Samsung, that unit should be covered under the class action lawsuit settlement regarding bad power supplies that were install in many Samsung TVs. You can get additional information and contact numbers here
Do you mean the Epic or Epix? The model number for the Samsung Epix is SGH-i907, but it doesn't look like Samsung has published the model number for the Epic yet -- it can't be found anywhere on either the Samsung or Sprint site. The release date is slated for August 31st, so the model number should be made available before then.
